    Results 1 to 2 of 2
      Oct 2010
      Stockholm, Sweden
      Country Flag: Sweden
      New brake booster/Master cylinder does not work
      So i have struggle with my brakes for some times without any success.
      I have the DSE BB/MC combination together with Kore3 C5 front diskbrakes for AFX spindles. Rear brakes are GM 9" drumbrakes.
      The problem is, when a move my feet from the break pedal it will not release direct. It is a 1 sec delay before it goes bak to its top position.
      I have bench bleeded the master cylinder according to a Bendix manual that Tobin provided me with. I have bleeded the system with a power bleeder.
      I have replaced the GM distribution block to a simple t-block. I have mounted a 10 psi wilwood residual valve for the rear brakes. I have tested a new brake booster. Non of these thing have made the brakes work. Now I know that IŽam not alone since there is an other guy on this forum (Espen, are you here) with the same problem. He has the same set-up on his 2e gen Camaro. Does anyone have some input about this. The spring has arrived i Stockholm and I whant to drive my car .... Thanks / Magnus
      Pontiac Firebird -68, Deep tub, DSE 4-Link, ATS AFX-Spindle, KORE3 C5-Brakes,
      Vintage V40, Michelin PS2 255/40-17 335/35-17, 6.0L, CompCam XR265HR(212/218, 0.558/0.563, LSA115), LS6-Intake, Ported TB.
