    Results 1 to 7 of 7
      Rosin core solder? yes or no?
      I bought some rosin core solder to use on my wiring, but wanted to make sure it's okay to use.
      If not, I'll take it back on hunt down some 60/40 lead/tin solder.
      Apr 2004
      OKC, OK
      Rosen core is what you want for electrical wiring.
      Mike
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      dayton ohio
      so long as it is NOT acid core you will be fine.
      POLITICIANS & DIAPERS BOTH NEED TO BE CHANGED, AND FOR THE SAME REASON!
      NY
      Rosin is what you need for electrical!
      The needs of the many outweigh the needs of the few.
      I wanted to make sure, as I knew I didn't want acid core, that rosin core wansn't another name for acid core.
      Thanks!
      Waiting on some terminals and wire from Terminal Supply Co and I'm ready to go.
      Car should be running in a week or so, parts arrival and OT at work depending...
      Jul 2002
      Muskegon, MI
      I was just using rosin core last night. I think it is 40%lead and 60% tin. Something like that. Works great. Mabey other way around but you get the point.
      Adam_______Offical Car Name "ILLUSION"
      383 Stroker, Stock cast heads, T-56 tranny, 4.11 gears, 2002 T/A dash, 4th gen interior including seatbelts, power lumbar seats, 18" Budnik Wheels, Hydraboost, QA1 shocks, DC Controller, Power steering conversion, fuel cell, unique exhaust set up........
      ILLUSION Website-----------Old Website--------------My Car on Lateral-g.net----------- Need something designed?-AdFabDesign
      Can't wait, I should get my Quickcar cables this week and first of next my stuff from Terminal Supply and I'll get to hear the motor run again!
