    Results 1 to 7 of 7
      Feb 2012
      73 Camaro rear end
      I have found a rear end with a 4.10 posi and disk brakes from a post 81 Camaro. Suppose I cut the coil holders off and mount a carrier for the leaf springs. Will it fit? If so, reason not to do this?
      Oregon
      Post '81 meaning '82 through '92 for the third generation or '93-'02 for the fourth generation? What size ring gear, 7.5", 7.625", 8.5"? 10-bolt or Borg Warner 9-bolt? Do you have any more information and/or pictures of the rear end, ID tag, etc?
      Tobin
      KORE3
      It's what I does.
      Jun 2006
      Katy,TX
      Not sure if 73s were too early for 8.5" 10 bolt and had an 8.2 but that is still better than the 7.5" etc late model ones.
      1978 Black Trans Am 455 Edelbrock heads [email protected] through mufflers on pump gas
      1981 Trans Am 400 stock type motor
      79 Camaro getting a 500" 695 hp IA2 Pontiac motor
      1965 GTO project car
      470ci/Chevy dual quad 409 604 HP 64 Impala SS project
      2004 Pulse Red GTO
      Jul 2010
      Sacramento, CA
      The third and fourth gen f-body rear ends are substantially weaker than the stock 2nd gen rear end. If all you're after is disc brakes, you can bolt the late fourth gen brakes right on to the 2nd gen axle.
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Jun 2010
      Deployed
      Quote Originally Posted by SLO_Z28 View Post
      1979-81 Trans Am rear disc is an easy swap.
      1970 Camaro/DSE build
      Orlando, Fl
      Quote Originally Posted by Skip Fix View Post
      My 73 has the corporate 8.5" 10 bolt...
      Here is a cut a paste from an article discussing where to find the corporate 10 bolt:
      You can find a 10-bolt 8.5-inch differential in any of these cars or trucks:
      1971-'76 Chevrolet full-size cars
      1994-'96 Impala
      1971-'81 Buick full-size cars
      1973-'77 Buick Gran Sport
      1972-'77 Pontiac GTO and Le Mans
      1970-'81 Chevy Camaro and Z28
      1970-'81 Pontiac Firebird
      1971-'77 Olds Cutlass and F-85 and Pontiac Grand Prix
      1971-'79 Chevy II, Nova, Buick Skylark and Olds Omega
      1973-'77 Chevelle, Malibu and El Camino
      1971-'77 Pontiac Ventura and Phoenix
      1971-'81 Pontiac Bonneville
      1973-'77 Monte Carlo
      1973-'77 Buick Apollo, Regal and Century
      1980-'94 Chevy ½-ton and ¾-ton pickups
      1977-'94 GMC Jimmy and Chevy Blazer
      Nick DiPrenda
      Aug 2005
      Hamilton, NJ
      2nd gen OE rears
      1970 - 8.2" 10 bolt; 12 bolt
      1971-1981 - 8.5" 10 bolts only
      1982+ up f-body rears are junk.
      Scott from NJ.
      Vent Windows Forever! ...
