View Full Version : Centerforce SBC to T56 Conversion Flywheel
senor_camaro
02-21-2012, 02:01 AM
Flywheel to convert SBC 350two piece rear main to accomodate Lt-1 T56
will throw in flywheel bolts as well. just needs a resurface.
asking 300 shipped
https://static1.pt-content.com/images/pt/2012/02/6915238623_48aa333f73_b-1.jpg
https://static1.pt-content.com/images/pt/2012/02/6915236765_d919d1d3b0_b-1.jpg
https://static1.pt-content.com/images/pt/2012/02/6915232483_190cdc04bd_b-1.jpg
badazz81z28
02-23-2012, 03:37 PM
May I ask what makes this flywheel different than the reguar SBC? IS this required for Hydraulic pressure plate?
vande596
02-26-2012, 08:15 PM
If I understand your question right, this flywheel is needed because the flywheel bolt holes on a two piece rear main seal block are further apart than on a one piece pear main seal. the hole in the crank for the flywheel on a one piece RMS are basically flush with the back of the block while the holes on a two piece RMS crank stick out. This creates an offset which needs to be compensated for. another reason for the special flywheel. Hopefully I touched on your question.
I had the same question when i was going to mount an lt1 to my sbc 327 but i changed directions.
But good luck with sale. Should sell quick!
senor_camaro
03-07-2012, 11:42 AM
Sold
