Results 1 to 7 of 7
02-12-2012 #1
- Join Date
- May 2011
- Posts
- 19
looking to upgrade master cylinder
i looked around for baer and wilwood to see if they had a direct replacement for my car but found nothing. i have poor braking, but all new calipers, rotors, pads, and rubber lines all around. im sure the original master cylinder is bad (squirts up when applying brakes) which is causing me to have poor braking. i plan on keeping the stock 4 wheel disc for a while until they're worn out, or i upgrade to a 12 bolt and get a wilwood kit. i need some pointers on getting something that will bolt up to the stock booster
1986 Camaro Z28. TPI fueled 383. 430 hp, 466 lb ft. Still a work in progress but driven often
A third gen that does more than go in a straight line
