View Full Version : tilton 2 pedal 3 master cylinder setup anyone use it?
wicked68
02-09-2012, 10:16 PM
http://www.tiltonracing.com/pdfs/98-1206.pdf
anyone use this or soemthing simlar? I am looking at it to move my mcs inside the passenger compartment
thoughts?
James OLC
02-10-2012, 07:59 AM
I have the firewall mount version. Works well, no issues. Expensive and overkill but very nice regardless. You have to be very mindful of rigidity and you have to be 100% perfect on alignment or you can run in to binding issues. I would probably go with the reverse mount if the room was there just to avoid some of those issue.
Matt@BOS
02-10-2012, 09:19 AM
I have the floor mount pedals. As James has said, by the time they are installed, they are expensive. Can you fit everything, including the fluid reservoirs under the dash? would you want to put the reservoirs under the dash? I think servicing anything would be a nightmare...
Matt
wicked68
02-13-2012, 07:51 PM
yes i have room under the dash. my dash is custom made and has 2 bolts on each side that hold it to the roll bars - so its really easy to take it out for serivce work.
sounds like the reverse mount I looked at is the way to go. thanks for the feedback
