    Results 1 to 20 of 26
      Jan 2010
      Somewhere out there
      Seeking Mesh rim recommendations on a budget.
      Any and all recommendations are greatly appreciated.
      sub $500 range each preferrably.
      I'm looking for some 18" Mesh rims with powdercoated centers for my 1978 Camaro.
      I'm not looking for the ultimate 3 piece American made bleed your wallet for $1000 per rim stuff. LOL
      I'm trying to find some budget one piece rim options for street usage.
      Rims that are powdercoated, machined lip, and have proper lug pattern 5x4.75 and depth for the rear (backspacing)
      I got my Foose Legends from Driverz Inc for just $260 a rim for my 442 and I love them.
      Lots of import rim options and ZR1 options but none seem to be recessed.
      I'm shooting for the Crusher Camaro's look , but I know those are Boze and $$$.
      Birmingham, AL
      Rushforth Night Train or one of the New Gen mesh style wheels.
      Stephen
      Jul 2010
      Sacramento, CA
      New Gens or CCW's are gonna be THE budget choices.
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Dec 2009
      Check w Tony - nine ball. He had a line, Forgestar I think, that was less than 2k for all four.
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Jan 2010
      Somewhere out there
      Those Forgestar mesh are a different style, that's all I can find on their brand.
      http://www.pyspeed.com/product-p/frs-8003.htm
      Not many options outside of CCW I guess......
      I'm contemplating just baking my Centerline galaxy's for a day and then powdercoating them instead.
      Quote Originally Posted by SLO_Z28 View Post
      Harlan, $1000 per New Gen rim isn't a "budget" option.
      Nice, yes. Budget, no.
      I'm not the type to dump $4,000 on rims. I'll spend $2000 or thereabouts.
      Oct 2011
      Quote Originally Posted by CreepinDeth View Post
      BBS wheels has some cast aluminum mesh rims in the sub $500 range. You may wanna give them a look.
      Nov 2011
      San Diego
      What wheel is on this car? Looks really nice.
      Jul 2010
      Sacramento, CA
      NewGen has several options in the $500 each range Stacey. Call DriverzInc for their new phone number, but they probably aren't as busy not that they're out on their own.
      On my car 11.5 or 12 inch wide CCW's all around are a goal. Might buy them and do some fender flares later this year.
      -James
      Birmingham, AL
      I would email New Gen or A Rushforth dealer, I have gotten quotes much more reasonable than 1k per wheel as long as you don't go wider than ten inches.
      Stephen
      there was a guy that made a couple of sets of 18" GTA replicas for his GN. he tried to sell one set, but i don't know if anyone ever bought them. he was asking right around $2k for the set. i think he's a member here.
      Indiana
      http://rimsntires.com/wheel.jsp?bran...=Vengeance%20B
      Try that link, I know the backspacing isn't perfect but with hub rings and spacers may work? I am looking for cheap options to run 18x9 or 18x9.5 on the front and rear of my 68
      Aarik
      68 Camaro LS2/T56, Jake's Rod Shop C6 Subframe, JRS torque arm. Ridetech TQ Shocks
      May 2007
      las vegas
      AJ
      1970 camaro rs, z28:pro-touring?... i wish
      93 trans am
      Oct 2006
      Corona, CA
      Thanks AJ, I was going to recommend the same thing!
      Jan 2009
      Huntington Beach CA
      XXR makes a mesh wheel, and they're cheap if the fit is right
      Mar 2010
      Okinawa, Japan
      Maybe a Beyern BMW wheel, if you're ok with the 5x120 vs 5x120.65 thing? The "Mesh" is pretty close. Comes in an 18x8.5 and 18x9.5, with a minimum of ET15 offset (5.4 and 5.8 backspacing respectively). I'm running a different pattern of Bayern rims on a G-body with the same offset and am happy with the fit and finish. Pretty light for a 1 piece too.
      Edit: About $250/ wheel btw. and here is a pic http://www.beyernwheels.com/BMW_whee...n_typemesh.php
      Jan 2010
      Somewhere out there
      NewGen rims are kinda similar but not similar.....
      The XXR's are not bad, and VERY inexpensive.
      Quote Originally Posted by carguykeith View Post
      This style is what I'm seeking.
      Those do look pretty smooth. Look just like the ZR1's rims but without the Beyern logo.
      That can be covered up I'm sure or painted over. No big concern there.
      I'm not sure about the differences between the 5x120 and 5x120.65 thing to be honest.
      Trying to understand if that's going to be an issue or not.
      Oct 2006
      Corona, CA
      You are preferably going to want the 5x120.65, since that is equal to a 5x4.75" bolt pattern, and that is what your car has. I have seen guys use wheels with 5x120, but ideally you would want the correct bolt pattern. That is the correct way to do it.
      Mar 2010
      Okinawa, Japan
      The logo is only on the center cap, which is removable so very easy to modify. I was originally planning on just putting a black sticker over mine, but just left the logos.
      As to the 120 vs 120.65, Driverzinc is right the best way to do it is have 120.65. It's up to you if you are comforatable with your safety knowing that the wheel studs are .025" further apart at the axle flange than at the wheel. I made an educated decision on my vehical and determined that it was acceptable, but I wouldn't just blanket recommend the practice to everyone.
      Jan 2010
      Somewhere out there
      I'm aware that the 5x4.75 = 5x120.65
      But like you just said, people are using 5x120mm rims, I'm just not sure what the difference really is that matters if people are doing it.
      I guess I'm just not understanding what that .65mm difference is, and if it's that crucial.
      I guess I need to really look into this more because I'm not quite envisioning the difference in my head.
      If I could see what it is, I'd have a better way to gauge it.
      I'm reading there are adaptors that are inexpensive to make this work with no issues too.
