View Full Version : Invisible wiring? how to?
john55blaze
01-30-2012, 03:18 PM
Hey all! First of all I hope this hasn't been discussed in length elsewhere (I searched a lot), but I am looking for ideas and pictures of what and how people are hiding all of their wiring & hoses; routing/plumbing anything and everything. I look at all these cars and some of the engine compartments are cleaner than the plates I eat off of yet they are running heaters, a/c, stereo systems, fuel injection, etc, etc...How do you do it?! Engine harnesses, coil relocation (LS motor), loom material (kinda like that funky stock plastic stuff only classy), bulkheads through the firewall for heater hoses, fuse blocks, grounds, powered distribution blocks, filler panels, suppliers...I want to smooth my firewalls and have a minimum of things poking through and I want as much of my wiring to be hidden or blend into its surroundings. The last vehicle I did was my '55 chevy truck with a TBI and everything about the engine compartment screamed amateur, it was cluttered and has always bugged me, but it was my daily driver...! I am now re-doing it with a 6.0LS and will be doing the same engine swap in my '69 Camaro. Oh and to make it more fun/difficult I would like to keep things reasonably priced :fingersx:. I thank you all in advance for sharing your tips, tricks and experince
amargari
01-31-2012, 05:29 PM
Hiding wires takes planning before you finish painting anything.
I moved the wiring bulkhead into the fender well and ran your wires through the fender to the front headlights.
For the engine you try to run wires up from the back of the engine and through the tunnel.
For the alternator you can mount it low and then you see no wires or run the wire straight down the front of the block behind the mounts.
I have seen people also run wires through braided hoses so you can't tell they are wires.
Hope this helps.
BulldawgMusclecars
02-01-2012, 02:25 PM
First, I'd recommend using some type of aftermarket wiring harness (AAW, Painless, E-Z Wire, something of that nature), since you're going to need a lot of extra wire in most cases to properly route it out of sight. It can be done with factory style harnesses, and I have done it that way, but count on making lots of splices, or adding quick disconnects (Weatherpak, round Mil-Spec style, etc.) or bulkheads to accommodate it. You'll also need a lot of extra wire, which can be pulled from late model cars in salvage yards to get all the odd colors necessary to keep the color codes the same. I did this on an '87 Firebird show car several years ago, and gutted the harness from two other cars to get all the wire I needed. For new wire, connectors, sleeving, etc. I mostly use Del City and Aircraft Spruce and Specialty. Aircraft Spruce offers lots of nice wiring harness sleeving, which I use whether it can be seen or not for wiring protection, and also shrink wrap in rolls in a variety of sizes.
rivs68
02-01-2012, 03:27 PM
You will also need patience, it takes more time and planning to do it correct, figure out where to hide what components, like relays, ign. box, etc...so you have a plan on where and how to route what circuits.
When I did mine I ran all the wires to their destination then wrapped the bundle, anchored where needed. I did't cut and terminate anything until I was sure I had it routed the way I wanted it and all needed wires in the bundle...adding a wire into an already finished bundle is a pain. Also try and think of anything you may want add down the road, and run the wires for those things now, not later...
Lots of wire ties, connectors, solder, heat shrink, and loom material....
Have fun, and the results are well worth the extra time and effort....
john55blaze
02-01-2012, 03:31 PM
Great ideas, thank you! Any of you guys have pictures (in progress, hiding spots, or other?)
rocketrod
02-01-2012, 06:01 PM
What he said!
parsonsj
02-01-2012, 06:18 PM
One can go too far with hiding wiring. Electrical components need to be viewable for service, and well-routed wiring can be visible and good looking.
BulldawgMusclecars
02-02-2012, 06:54 AM
Very good points, John. Its easy to go too far, and have a vehicle that is very tough to service.
John510
02-02-2012, 11:27 AM
:postpics:
02-02-2012, 06:15 PM
invisible electrical tape...right next to the gap reduction spray. LOL
Clean is just as nice as unseen.
esenior
02-02-2012, 08:17 PM
Did someone ask for pictures? :)
For my project, I used braided stainless sleeving (http://www.jegs.com/webapp/wcs/stores/servlet/KeywordSearchCmd?storeId=10001&catalogId=10002&langId=-1&Ntk=all&Jnar=0&Ne=1%2B2%2B3%2B13%2B1147708&searchTerm=stainless+sleeving) from JEGS to hide my wires. Just make sure that the wires are well protected. I used vinyl wrap around the wires first, then covered with the braided stainless, and then used a short piece of shrink wrap at each end of the braided sleeve to give it a finished look. Here's the driver's side in progress:
https://static1.pt-content.com/images/pt/2012/02/69CAMAROPT_110724_01MJPG-1.jpg
I ran my main harness through a billet firewall port (B16) (http://www.watsons-streetworks.com/billet_firewall_trim.html) directly behind the motor as low as I could. Would be more hidden if you routed them through the tunnel, but in my case, there wasn't enough room between the tunnel and the scattershield. You can barely see the port behind the fuel line:
https://static1.pt-content.com/images/pt/2012/02/69CAMAROPT_110924_01MJPG-1.jpg
Wires to accessories (alternator, AC, etc.) are run through braided along the edge of the intake. Most people don't even notice them. I also ran the wires underneath my accessory brackets and used a small line clamp to hold them in place.
For wiring to the front end (headlights, parking lights, horns, electric fans, etc.), I ran my wiring through the kick panel and through the firewall under the fender. I mounted breakers and relays on a block off plate under the fenders. I also hid my HID ballasts and my dryer there. To get to parking lights and to the driver's side, I ran a harness up under the lower cowl panel.
https://static1.pt-content.com/images/pt/2012/02/69CAMAROPT_111219_09MJPG-1.jpg
For my hoses, I also ran them under the fenders and put bulkheads on my inner fenders up near the core support. Passenger side has my heater and AC hoses and the driver's side has the brake lines as well as the hoses from my power steering box.
Bulkheads on the firewall:
https://static1.pt-content.com/images/pt/2012/02/69CAMAROPT_111127_01MJPG-1.jpg
Here's some early pictures during mock-up:
https://static1.pt-content.com/images/pt/2012/02/69CAMAROPT_100606_09MJPG-1.jpg
https://static1.pt-content.com/images/pt/2012/02/69CAMAROPT_100606_21MJPG-1.jpg
Here's a couple of current pics:
https://static1.pt-content.com/images/pt/2012/02/69CAMAROPT_111231_10MJPG-1.jpg
https://static1.pt-content.com/images/pt/2012/02/69CAMAROPT_111231_11MJPG-1.jpg
I understand what others are saying about easy of access, but if you are going for the look, you may have to make some sacrifices. I'm not saying form over function, just a balance of form and function. It all depends on what your own goal is.
---Eric
Very good points, John. Its easy to go too far, and have a vehicle that is very tough to service.I have to agree also. I personally am not in favor of the current trend to try to "hide" everything in the engine compartment. Some go so far as to fabricate intricate covers to hide the engine completely. It's an engine! Why would you want to hide it? Celebrate it! Isn't this one of the number one complaints that many people have with modern engine compartments, that you cannot even see the engine? And we've got cool hot rods or muscle cars where the engine can be proudly displayed, and yet choose to hide or disguise it?
It is true that wiring and plumbing can be a real eye sore. But it can also be really cool. It does take a lot of thought and planning about how to route things cleanly. And it requires use of the right (usually more expensive) components.
Here are some pics of my engine compartment after re-wiring and redoing a lot of the plumbing, and changing the engine. This is on a 56 F100.
https://static1.pt-content.com/images/pt/2012/02/Enginebeforeandafter-1.jpg
https://static1.pt-content.com/images/pt/2012/02/frontleftbrakehardline2-1.jpg
Twentyover
02-03-2012, 10:44 PM
It all deends on what your own goal is.
---Eric
Can I ask where you got the bulkhead grommet for the wiring pass-thru?
Ron.in.SoCal
02-04-2012, 08:34 AM
It was a link in his post, Mr. Fast:
esenior
02-04-2012, 08:40 AM
Yep, like Ron said, I bought these from Watson's streetworks. The one behind the motor is the B16 and the one in the picture is the B01ST (split and pinned).
Ron.in.SoCal
02-04-2012, 08:45 AM
Props eSenior. Your engine bay looks great! I'm wondering if the B05 will fit an LS harness. Looks a bit small?
BulldawgMusclecars
02-04-2012, 11:14 AM
Earl's sells a product called Seals-It for running plumbing through, but wiring bundles should work just as well. I'm thinking about ordering a few of these in different sizes to play around with.
http://www.holley.com/HolleyNews/article.asp?ID=111
Twentyover
02-04-2012, 12:39 PM
Must begetting old. Took me three reads, after you pointed it out, before I found it. Must be bad eyesight. Yeh, that's the ticket, my eyes are going bad....
Twentyover
02-04-2012, 12:44 PM
Double post- Must be sumptin seriously wrong in my head
esenior
02-05-2012, 05:43 PM
Thanks for the props, of course my friends all think I have OCD...they're probably right!
The hole in the billet plate is 15/16" and the ID of the grommet is 5/8". If 5/8" is too tight, you could always wrap the harness and put it through without the grommet, or you could even drill out the plate and install a larger grommet.
john55blaze
02-06-2012, 10:59 AM
Awesome stuff guys! Thanks a ton
68fusion
02-06-2012, 07:34 PM
Been done quite a while but "planning" as many have said reaps rewards.... several mock ups with ALL items is a must. Used a lot of the woven wire loom and liked it but required to "unpin" connectors or put them on after routing. This loom is not split like the plastic oem stuff but is very flexible. Most of the ugly stuff is in the tunnel area and ecm and coils are mounted inboard.
55173
www.customclassicsandrestorations.com
