    Results 1 to 12 of 12
      Apr 2011
      North NJ/SW Virginia
      Brakes On A Budget
      I'm currently in the planning stages of converting my all orginal 1970 Pontiac Lemans into a semi-proturing car. I want to know what is the best brake system for the money. Right now I have the orginal power brake setup with disk up front and disk out back. The only real changes have made is I changed the rotors, put on rebuilt calipers, and ebc pads. I want more modern brakes. What is the cheapes way into good brakes? I know this might sound stupid (cheap and good) but I'm a student and I'm on a limited budget so work with me.
      P.S. has anyone worked with the c5 brake set up form cpp?
      Greenwood, SC
      get the c5 conversion from kore3 industries.
      Or if you can outsource the rotors and calipers, just get the brackets, hardware, and flexlines.
      http://www.kore3.com/index.php
      JC Scott
      Sep 2009
      You can find a better price if you buy used. I waited and only have about 325the into my front setup. Just need to install it. C5 is by far best bang for the buck.
      san jose,ca
      I did the c5 set up, I might have the backing plates and rear calipers if you want me to look for u
      Eli
      68 camaro more plans then funds! lol
      http://s34.photobucket.com/albums/d1...view=slideshow
      Apr 2011
      That would be great. Quick question, on the front the disk and the hub is one unit which mounts on the spindle, so if I move up to c5 brakes I will need a hub right? Where do I get the hub?
      san jose,ca
      You use your stock hub you may need to turn it down a bit I did a write up that covers the install
      Eli
      Apr 2011
      do you have a link where I could read your write up.
      bowling green,ky
      Ive got a complete front and rear ls setup with drilled and slotted zinc coated rotors calipers are painted red with duplicolor brake paint that I will be removing shortly when I switch to c6z06 brakes if you r interested
      san jose,ca
      Jul 2010
      Sacramento, CA
      Everything you need for a conversion for $300:
      http://customworksproducts.com/brakes.html
      That's as bang for the buck as you'll get.
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Dec 2011
      Planit Oahu, Hawaii if you don't belive me check shipping prices
      ok I don't remember how much I spent. but it was not a lot for the front setup.
      1st I started off with a set of C4 HD 12.75 rotors from local parts store.
      then a set of '98 Camaro LS1 powered SS front calipers from E bay, (rebuilt inspected, returned one not safe to use)
      took the stock rotor / disk and had a machine shop (witch I will not use again) cut the rotors off the hub.
      have your shop face the hubs about 1/8 - 1/4"
      cut the caliper mounts off the stock spinals.
      set every thing to together to make a templet out of poster pepper, then out of sheet Madel.
      I made mine to mount to 3 of the bolt holes, (kits available only use 2) re-drilled and taped the holes they were some crazy off metric. the mounting bracket 1/4" mild steel. used the rotor to center the caliper bracket (right / left, & depth)
      as of jan22 2012
      rotors- auto zone J55 C4 vett. $69.99.
      Calipers – Ebay with brackets, $100.
      Machine shop – I think mine bill was $200. I think I played to much, & they did the minimal amount of work to complete the job.
      I had the steel.
      Dec 2011
      ^^it all works very well, and stops my '92 Camaro very good!!
