    Results 1 to 5 of 5
      Dec 2007
      Middletown, Ohio
      69 Camaro LT1 swap - Want to add AC
      I am in need of some guidance and I figured you all could help.
      I have swapped an LT1 into my 69 non factory air car and I want to add AC. I have purchased the Bowers LT1 compressor brackets already. I have the factory compressor, Condenser, and dryer from the 96 Camaro for the LT1. Can I use all of these parts on my 69? I was hoping to just get by with a Vintage Air evaporator kit, new ref lines, controls, switches, ducts, etc.
      i am on a tight budget so I can only afford to do this once so I need to do it right.
      What parts of mine can I use (if any) and what will I need to buy to make it all work? Or should I just save up for a complete Vintage Air kit next year?
      Thanks in advance,
      Dustin
      Aug 2008
      ocala fl
      Country Flag: Wales
      I don’t now if condenser will fit you’ll have to try it. If not you can get a universal condenser or a condenser for the 69 you’ll have to get the hoses made. It shouldn’t be to hard. you’ll probable need to get electric fans to. Probable not the answer your looking for but good luck
      ''Courage is being scared to death
      - But saddling up anyway''.......John Wayne...
      Anthony
      Dec 2007
      Middletown, Ohio
      Thanks for the reply.
      I am also using the radiator and dual electric fans from the LT1 already so mounting the Condensor should be easy.
      Nov 2001
      St. Cloud, MN
      FWIW I used the stock compressor from the 95 on my swap/Vintage Air conversion.
      Jon
      71 Nova LT1/4L60E
      England
      And when fitting take the passenger seat out as it's a pain to fit the unit,
