    Results 1 to 6 of 6
      Jan 2010
      Will a 4 Ga Power amp wire be ok?
      Hey guys, I thinking about buying this amp and was wondering if a 4 ga. power amp wire will be enough to power this amp? I'm thinking I need 18 feet or so.
      http://www.crutchfield.com/p_500PDX5...-5.html?tp=115
      Waunakee, WI
      It's a class D amp. You'll be fine with 4 ga. at that distance.
      Marty Koppes
      Jan 2010
      Quote Originally Posted by martZ View Post
      Thanks Marty
      Oct 2011
      What does Alpine recommend? There are many wire guage calculators on the internet. Look at the fuse that comes with the amps, then find the gauge that will carry that amperage over the distance you are running it.
      Of couse the amp will never draw the current of the fuse but this will get you there. Or, you can look at the owners manual of the amp or call Alpine. Class D is more efficient, meaning it actually puts out more of the power it is rated at, so not sure if it will draw less power than an A\B amp. I always follow the owners guide.
      Oct 2011
      Here ya go!
      http://a248.e.akamai.net/pix.crutchf...00/500PDX5.PDF
      4 guage is what owners manual recommends.
      Sep 2002
      So. Cal
      quick calc, 600watts/12volts = 50amps. Amp fuse rating is 2 x 30 amp.
      If I remember right, 4ga is good for somewhere around 100amps.(depending on wire quality and length)
      More than adequate.
      Ron DeRaad
      68 Camaro RSx
      Darton Sleeved LS9 - 434ci (4.155x4.00)
      AFR LSX245 Heads (12:1cr)
      660hp/588tq
