View Full Version : '92 Camaro, IRS
FlyDoc
01-07-2012, 11:33 PM
I started off with a run of the mill 92 RS, with a week 305 & auto.
https://static1.pt-content.com/images/pt/2012/01/l_df7bf685ad9b5670cad263bea999042f-1.jpg
https://static1.pt-content.com/images/pt/2012/01/l_41ea165dfc640367b080776e0c1b626d-1.jpg
from there I did an LT1 swap, with an auto. then one day the trans made a loud bang, and I got a bill from the fire department for a Hazmat clean up.
https://static1.pt-content.com/images/pt/2012/01/DSCN0077-1.jpg
then I stepped up to a aluminum flywheel and a 6 speed.
https://static1.pt-content.com/images/pt/2012/01/101_0945-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_0007-1.jpg
https://static1.pt-content.com/images/pt/2012/01/101_0949-1.jpg
my boys hard at work
https://static1.pt-content.com/images/pt/2012/01/101_0948-1.jpg
FlyDoc
then I found a Dana 44, Vett IRS. the install of the IRS
https://static1.pt-content.com/images/pt/2012/01/IMG_3127-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_3832-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_3844-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_3849-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_3850-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_3858-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_3860-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_3874-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_3883-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_3887-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_4053-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_4059-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_4143-1.jpg
Jim Nilsen
01-08-2012, 05:17 AM
Looks like you had all the fun we all have when making a Cormaro!
SLO_Z28
01-08-2012, 08:22 AM
Cool project! How much static negative camber could you get with that rear end?
gofastwclass
01-08-2012, 01:01 PM
Cool, I admire your courage. :) I remember the days of working in the driveway with barely enough hand tools.
exwestracer
01-08-2012, 04:34 PM
That really could have been welded mo bettah, brah....
FlyDoc
01-09-2012, 12:05 AM
I have a nicely stocked tool box, a mig welder, and the most used tools for this project a saws-all, and 4"grinder. it's the cool stuff that would have maid it easier!
FlyDoc
01-09-2012, 12:25 AM
the undercoating used was a head-ache! I have no idea what it is, but I heated it with a propane torch, scraped it, wire wheel on the grinder, wax and grease remover, and it still seeped out of the metal when I welded it. The photos make it look worse than it is.
oh ya, I could croquette your work form a photo.......
count to ten.....
go Fu@k your self!..
and I'm not your Brah...
WolfManSpecial
01-09-2012, 07:23 AM
count to ten.....
jajajajajajajajaja
nyciti
01-09-2012, 07:35 AM
"oh ya, I could croquette your work form a photo.......
count to ten....."
....I agree with you! However, you are posting on a forum on the internet which btw is public so you automatically have public opinion. No need to get defensive it just means / shows you lack confidence in yourself and or work, since in fact it is so easy to "croquette your work form a photo......." from the warmth and safety of a computer from who the f*ck knows where.
And on that note, good work!
Bryce
01-09-2012, 08:07 AM
Cool build!
I hope you and Ray know eachother.
BuddyP
01-09-2012, 09:36 AM
I like the third gens! Awsome build, keep the photo's coming!
FlyDoc
01-09-2012, 10:37 AM
that was taken before the grind and re-weld / make it pretty. OH well, my wife says that since I left the Army my filter has not been working...hehehe.
no I do not know this Ray.. but we would probably get along. I get long with almost everyone, that is in to, cars, guns, hunting, motorcycles.
exwestracer
01-12-2012, 01:26 PM
I teach welding on a daily basis, so yeah, I can "critique" your work from a photo...
And I didn't point it out to be a d**k, I pointed it out because it's holding the rear suspension under your car and could cost you your life...
I didn't say you couldn't fabricate, or your car sucked, or it was a stupid idea...NONE of which is true.
But hey, throw the attitude all you want. I sleep fine at night.
SLO_Z28
01-12-2012, 03:28 PM
so, uh, like I asked... how much rear camber can you get with this setup? Seems like a cool swap, as you can gain rear camber, compliance, and eliminate pad knock-back!
ryeguy2006a
01-12-2012, 03:38 PM
I really like the idea. Nice work, what gears are you running?
FlyDoc
01-21-2012, 05:43 PM
I don't know? but I can get the 295's to stand up on the inner 2" with the outer tread off the ground.
FlyDoc
01-21-2012, 05:46 PM
the vet gears, I think there 3:43.
FlyDoc
01-21-2012, 06:15 PM
I also put in Sphon K & A-arms with Del-sphere ends, 2" Race Craft drop spindles,& weight jacks round out the front end.
the breaks consist of C4 HD 13" rotors, with 99 SS Camaro calipers.
with some long tube headers for the 3rd gen.
https://static1.pt-content.com/images/pt/2012/01/IMG_40961-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_3989-1.jpg
https://static1.pt-content.com/images/pt/2012/01/DSCN016521-1.jpg
https://static1.pt-content.com/images/pt/2012/01/DSCN01311-1.jpg
FlyDoc
01-21-2012, 06:27 PM
^^is prior to the race craft spindles,
https://static1.pt-content.com/images/pt/2012/01/IMG_5392-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_4117-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_4116-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_40281-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_3995-1.jpg
deadman
01-22-2012, 05:02 AM
cool build! what do you think of the cornering with the swap? was it worth all the work?
FlyDoc
01-27-2012, 02:37 PM
the limited time that I have got to drive the Camaro, it was defiantly worth the effort and time!
I have been having some break issues, but I think I have them sorted out. the factory proportioning block was leaking, so I put on a vet master cylinder with one integrated in to the master.
gator1505
01-27-2012, 05:05 PM
if they are factory gears they are more then likely a 3:07 or 2:73
Nice build I thought about doing that when I had me IROC a few years ago
andrewb70
01-27-2012, 06:02 PM
count to ten.....
More of that and you will have to grace another forum with your presence.
Rule #3
https://www.pro-touring.com/showthread.php?9762-Pro-Touring-com-g-Machines-com-Forum-Rules-Please-read
Cool build. Let's make good first impressions.
FlyDoc
09-13-2013, 12:54 AM
Well sence the last post, I have cooled off some, mabe, but what ever.
The camaro was stolen, but I was able to recover it. They rolled it down the hill out of my driveway, they were unable to start it, in the processes they destroyed the wiring harness, steering coulm, dash, console, windshield.
They also got a pair of helmets, all my tunes about $2000. of equipment, and worst of all a check book! And Wrote $7000.00 worth of checks in 2 days, in about 14 different places most of them were to a person that they had Stolen there identity, so they got over $5000, in cash and a TV from Walmart.
About all I have done is removed the windshield & dash. We are in the process of moving so maybe in a month or two I will get it in side and go at it. The first thing is to mount the '04 GTO dash, & consul, then go on a major diet, cage, file tank relocation, plan posable front suspension mods.
FlyDoc
12-15-2013, 03:19 PM
It has been a long time for the Camaro!
As I said in the last post she had been stolen and that really took my ambition to get things done.
so now after two moves, a small garage agine! having the interior destroyed, and the felling of violation!
I think I have a solid build plan for it. I'm still having some issues with the violation part ( I know man-up, get over it! and move on!)
so in the last few weeks I have built a frame table (as I said in look backs on the IRS instal should of had one!) I have done it on a tight budget, so I can spend the $$ on the car. I started with a set of pallet racks, they are designed to hold about 8000lbs. so making a section 14' from to 8' rails with 2' of over lap I should have no issues. the cost so far is, $80. for the rack, $300 for wheels, then the part that I think is crazy! $250. for a 4'x8' 1/8" for the wheel platforms.
so the plan is to, pull all the floors, basically every thing from the bumper mount, and the pinch seams. Then a tube chassis, Keeping the IRS, adding upper A arms to the front end. going to push the motor back, 04GTO dash. this is the only variable to the build now is AWD, just depends on engine set back (foot room priority 1) I'm using C6 up-rights, so that will only be a hub change, and the springs/shocks are going to be push-rod/ cantilever. so I'm thinking that if it goes I wont have to replace a bunch of parts just add.
I have been fallowing a lot of threads here building ideas/plans for the Camaro.
like
Aerodynamics for track
silver fox
Safety
Unorthodox firebird
with a lot of others that I'm taking in lots of knowledge from.
well I guess we will see how things will go!
FlyDoc
08-16-2018, 07:02 PM
Just an update for all of you. has been a long while so one is due, after looking at other threads that just have gone silent in decided that I need to let you all know what has happened.
so after I got the frame table built, the house that I renting from "friends" go very complicated, they had not payed the electric bill for over 4 months, in Hawaii the electric Co. has got a law passed that the past bills stay with the house, not the person that holds the Account, so that was a knock on the door and you owe $4000. if you don't pay then we will disconnect and you wont have electricity tell you pay. well you know that if they not paying that they are not pay the mortgage. With all that we decided that we would move off Island back to Texas.
at this point the car was dissembled, and most of the front suspension was cut off. no one on the island wanted to continue the project, I could not find anyone that had the desire or knowledge to continue. the cost of moving to TX was not an option, so off came the good parts, and the rest was cut up into fit in a 4'x5' box and to the scrap yard.
the plan was to start a new 3rd gen here in TX, but I got a '73 Chrysler Conqure S III boat and have been restoring it I also have completed a '70 Chevelle SS 454, and a '51GMC pick-up.
all in a 2 car garage, so when these are done I have not decided weather i will start a 3rd gen, or start on my high school truck a '48 Studebaker pick-up, time will tell.
ryeguy2006a
08-17-2018, 11:57 AM
Dang, that is a pretty sad end to the car.
FlyDoc
08-17-2018, 05:29 PM
ya it was, but I still would like to do another one.
Motoracer838
08-19-2018, 06:06 PM
I hate when things go south like that...
Joe
