    Results 1 to 9 of 9
      Jan 2010
      Which is a better speaker?
      Hey guys, which of these speakers is better?
      http://www.crutchfield.com/S-jnBpibA...-462-9cfp.html
      or
      http://www.crutchfield.com/S-LsR5lvT...er-reviews-tab
      Steeler Country
      We have used Polk in all of our project vehicles....absolutely love them for many reasons but sound is #1
      Feb 2010
      Central Texas
      I'd go with the Polk speakers. I installed them for years and think they are great.
      bowling green,ky
      go with the infinitys. they are 3db more efficient(twice as loud in spl terms). So in a situation where they are running off of a deck and not a amp, the infinitys will give you a little more volume compared to the polks. They will also be a little brighter sounding.
      west michigan
      sound is one of those things that is a personal choice but I have the polk's in my camaro and am happy with them, but I had a friend with the infinity speakers and I liked those better. personally I would buy the infinity's but like I said. if there is any way you could go to a local audio shop and listen to both I would do that and make a decision from there.
      Chad Read
      Jan 2010
      Quote Originally Posted by CRead01 View Post
      Chad, do you remember if he was using an Infinity 4 X 6 speaker in the factory kick panel location?
      Tony
      west michigan
      Quote Originally Posted by tonyvol View Post
      Tony
      actually he had a 89 camaro and I am pretty sure they were in the dash.
      Chad Read
      Aug 2005
      Floyd, VA
      I don't know where you are mounting these but neither work well without a component mid-bass. They are both quality speakers. You really need to audition them and make sure the Infinity will fit your application with the offset magnet(sometimes they don't). I have used both of these, and for my taste, the Polk tweeters sounded too subdued and the Infinity sounded "forced" or harsh. Both of them needed to be crossed over above 150Hz to have any power handling. I pulled a set of these off the shelf http://www.woofersetc.com/p-7938-15-...-speakers.aspx and the tweeters sounded much better and it had good mids with a tiny bit more bottom than the others. They worked really well with 100 wpc amp crossed at 150. The Memphis aluminum/magnesium tweeters really stand out as far as sound quality. Do not put any weight into speaker specifications..... it means less than nothing. It is all in the listening. Also keep in mind that it takes 10 db increase for something to sound twice as loud. That is ten times more power, because our ears are not linear. 3db is twice the power but is only perceptible in A/B testing, and again, the specs between 2 different mfgs means nothing.
      If these are gonna be your only speakers for front stage (no mid-bass), I highly recommend figuring a way to adapt a 5-1/4" (or more) round setup. In this case, the Polk Signature Series is brilliant if the budget allows
      Politicians need to learn to be Americans instead of Republicans and Democrats
      If you are not part of the cure you are part of the problem
      12/22/2012: I remember the end of the world like it was yesterday
      Cornettsville, ky
      had both before i like kappas better
