sick63nova
12-21-2011, 08:36 PM
started out a stock nova intill i got ahold of it back in HS ever sense then things have been changing on it, stared out as just a cruiser for school an the shows, all started one car show where they had the autocross going on, thats changed everything. ever sense then i have been upgrading the car to start racing in the autocross at the show. Got a good start on it but there are still more thing i need to add to get it to where i want it..
FRONT SUSPENSION- CPP mini subframe kit (frame brace, tubular upper an lower control arms), Coil-overs, CPP 13inch big brakes, 1 1/8 solid sway bar, CPP 2inch drop spindles & steering arms
REAR SUSPENSION- Global west 1.5 inch lowering multi leafs, 1inch solid sway bar, frame connectors, lowered
RIMS- 17inch intros
TIRES- 235/40/17 BFG G-force KDW(rears) 215/35/17 (fronts)
MOTOR- just your standard SBC making around 350 for now
TRANNY- tubro 350 shift kit, 3500 stall
UPGRADES IN THE WORKS-
FRONT SUSPENSION- strut bar to tie the front end together
REAR SUSPENSION- 4link conversion
MOTOR- alum heads, bigger cam, change out gear drive, electric fans, change fuel system
TRANNY- 5 speed conversion
thanks for checking my ride out, ill try an keep the site updated with pictures, its been a fun project i've had the car sense i was 16 an im 23 now dont think i will ever sell it!
https://static1.pt-content.com/images/pt/2011/12/100_0312-1.jpg
https://static1.pt-content.com/images/pt/2011/12/100_0318-1.jpg
https://static1.pt-content.com/images/pt/2006/08/100_0323-1.jpg
https://static1.pt-content.com/images/pt/2011/12/100_0426-1.jpg
https://static1.pt-content.com/images/pt/2011/12/100_0424-1.jpg
https://static1.pt-content.com/images/pt/2011/12/100_0420-1.jpg
https://static1.pt-content.com/images/pt/2011/12/100_0421-1.jpg
https://static1.pt-content.com/images/pt/2006/08/100_0422-1.jpg
https://static1.pt-content.com/images/pt/2006/08/100_0431-1.jpg
https://static1.pt-content.com/images/pt/2011/12/100_0442-1.jpg
https://static1.pt-content.com/images/pt/2006/08/100_0445-1.jpg
https://static1.pt-content.com/images/pt/2006/08/000_0289-1.jpg
https://static1.pt-content.com/images/pt/2011/12/000_0306-1.jpg
https://static1.pt-content.com/images/pt/2011/12/000_0300-1.jpg
https://static1.pt-content.com/images/pt/2011/12/000_0302-1.jpg
https://static1.pt-content.com/images/pt/2011/12/000_0329-1.jpg
https://static1.pt-content.com/images/pt/2011/12/000_0330-1.jpg
https://static1.pt-content.com/images/pt/2006/08/000_0334-1.jpg
https://static1.pt-content.com/images/pt/2006/07/000_0326-1.jpg
https://static1.pt-content.com/images/pt/2006/07/000_0336-1.jpg
https://static1.pt-content.com/images/pt/2006/07/000_0337-1.jpg
https://static1.pt-content.com/images/pt/2006/07/000_0351-1.jpg
RIMS- 17inch intros
