View Full Version : Which car to get serpentine stuff from?
Rileys68Camaro
07-03-2005, 05:52 PM
I have a GM Performance motor, part # 12355345 which is the 300hp model.
What car should I look to get a serpentine setup out of? I need all the toys, brakets, ps pump, A/C etc.
This motor has the center bolt valve covers, but non-Vortec heads.
I have a Vintage Air Sure Fit kit, so I hope to find a serpentin setup that has a GM compressor that will work with it. Or something...
dipren443
07-03-2005, 06:02 PM
GMPP sells a complete kit with A/C compressor thats fairly reasonable and its everything you could need... Just a thought... Heres the link.
Serpentine Kit (http://store.summitracing.com/default.asp?target=partdetail.asp&autofilter=1&Ntt=serpentine+kit&N=305341&part=NAL%2D12497698&autoview=sku&Ntk=KeywordSearch)
https://static1.pt-content.com/images/pt/2005/07/nal12497698-1.jpg
Swifster
07-03-2005, 06:15 PM
Vintage Air's Front Runner system would work as well.
Rileys68Camaro
07-03-2005, 07:03 PM
I'd really like a Front Runner but it's kinda spendy. Cheapest I've found for it is about $1500. I've looked at the GM kit but I was hoping to get into a little cheaper for now and the GM kit seems bulky.
Thanks!
I just can't seem to find a v-belt alternator and powersteering bracket that's not $100 a piece. Just need something to get it going for now.
USAZR1
07-04-2005, 11:40 AM
Do you have the room for the longer water pump these kits use? Are you going to use an engine-driven or electric fan?
1988-92 F-bodies used a serpentine set-up that's easily adapted. Truck stuff would probably be the same parts,too.
Zefhix
07-04-2005, 01:07 PM
Does GM make a kit like that for BB that will support AC/Pwr steering/water pump/crank/alt? Thanks.....
-Keith
blown69nova
07-04-2005, 03:15 PM
88-92 camaro v8, 88-93 caprice and their GM counterparts use the same basic system as the new GM system you are talking about. I know because I checked some of the bracket part numbers and they match. This system fits very well on a 69 nova.
airrj1
07-05-2005, 08:17 AM
I had a '90 K2500 Chevy and the front system would have been a perfect retrofit onto my Chevelle. But when I sold the truck the new owner wanted to keep the WP etc. I am keeping my eye open for one in the local yard.
