    Results 1 to 17 of 17
      Oct 2005
      New Washington, IN
      Machining cast wheels, damaging?
      I had posted on another site about my wheels for my Iroc that I had the Hub hole enlarged to fit.
      Someone replied,
      "I hope that they are forged wheels as boring out a center hub can destroy the integrity of a wheel"
      Any truth to this?
      1971 Camaro 427 in waiting
      1988 C1500 Daily Driver
      Norwalk, Ct
      Country Flag: Wales
      Hmmm, not buying that as ALL cast wheels are machined afterwards, either to make the mouting face flat, the lug holes, machine the hoop and to make any size center bore (I've never seen an "as cast" center bore, how the hell woudl you make them hub centric???)
      My 64 Riviera has pretty much the largest hub bores out there and all three of the wheels I have used all had plenty of meat on them to get machined out (2 types of Coys wheels and TT2's). I woudl say as long as your not doing something silly in hoel size...your fine.
      Nick Townsend
      Pro-Vintage 69 Corvette
      64 Riviera Custom - 20's, air bags
      Shell Valley Cobra
      2005 Penske Racing Dodge Charger Nextel Cup Car "Rusty's Last Round"
      Rustburg, Virginia
      Maybe they were concerned of overboring the center bore to where there is very little material left?
      Lowell, MI
      Got a pic of said hole? Most likely, it will be fine unless the hole had to be so big that it created thin walled sections.
      Turbo Charged LS1/T56
      Oct 2005
      New Washington, IN
      I will get pics up.
      The hub is 2" thick, only 1" was machined and it was not even enlarged more than the other 1".
      Oct 2005
      New Washington, IN
      Here is a pic of the unaltered wheel.
      And here is the machined one.
      front view of unaltered wheel
      front of machined
      Oregon
      Well done...I'd run it.
      Tobin
      KORE3
      It's what I does.
      Oct 2005
      New Washington, IN
      Quote Originally Posted by Apogee View Post
      Tobin
      KORE3
      Coming from you, thats quite a complement! Thanks!
      I am waiting on an explanation from this guy. If I get one I will be sure to post here.
      Oct 2005
      New Washington, IN
      the guy that said this is an engineer according to his info.
      The fronts were machined out just enough to fit the hub, so the fronts are hub centric, now.
      Quote Originally Posted by Johnny Blaze View Post
      Doesn't mean he's a competent engineer. Just remember that for every guy that graduates at the top of his class, there's another engineer that graduates at the bottom of his class. When someone come up with aline like that,always ask them to explain it. If they can't,you can ignore it.
      And I'm an engineer. Won't tell you where I graduated
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Lowell, MI
      I see NO problems with that what-so-ever. I agree with above statement.
      Oct 2005
      New Washington, IN
      Sure looks like my lug nut holes, and the back mounting flange were machined at some point as well!
      Rustburg, Virginia
      Roll on. I think they will be fine.
      Dec 2008
      Detroit
      They're fine. The weight shouldn't be on the center of the the wheel, but on the studs. Plenty of metal left....
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Oct 2005
      New Washington, IN
      Here is the guys reply after I posted pics, and 3 or 4 people questioned his comment.
      "Theory is that a cast wheel is strongest when it is at the dimensions made when it is at the factory; cutting material can reduce the integrity of the hub mounting area and cause cracks that will lead to failure. If you are talking taking a file to scrape a little bit of paint, that would be fine, some wheels can't take an extra mm of bore before they start to fail, others can go 1/4" and be fine.
      And yes any wheel failure is going to be catastrophic, so check your wheels all the time for cracks around the hub area. "
      Lowell, MI
      I better go check my cast aluminum block for cracks...I'll be right back...
      Oct 2005
      New Washington, IN
      Thats what I was thinking as well.
      Funny thing, this guy has a 'performance shop' website that offers work. The only product listed on his site is custom forged wheels for 3rd gen f bodies.
