67greengt
11-14-2011, 05:51 PM
Ride tech formerly known as Air Ride Technologies Suspension Parts-
Tubular Upper and Lower Control Arms (Strong Arms)
Ride Tech Muscle Bar with Posi Links
Ride Tech Muscle Bar Triangulated 4 Link setup with Air Bags and optional internal ride height sensors (this makes for a much more accurate ride height setting as it uses sensor as well as air pressure - this is an $400 add on to each air bag)
MSRP on the upper/lower strong arms is $1100 usd
MSRP on the muscle bar front sway bar is $400
These control arms/sway bar can be used with either Air Bags or Coilovers (ridetech now makes adjustable coilvers to go with these kits)
Looking for $1200 on the control arms and the sway bar.
MSRP on the Air Bar 4 Link is $1300 - Looking for $1000
MSRP on the Rear Air Bags is 900 plus the 800 to have them updgraded with internal sensors - Looking to get $1200
Ride Tech 5 Gallon Air Pod with twin compressors, upgraded ECU to ridepro and optional Internal Sensors - brand new - used only to mock up the above suspension parts
With the options and add on's this sells for $2750
Looking to get $1900
The Ride Tech parts were only used for mockup, and have no actual miles on them. I decided to change engines in my car, and go a completely different route with suspension; as a result, I have no use for the ride tech stuff.
Also have 67-70 Mustang Baer Brake Hub assemblies with Baer Brake bracketry for 13 or 14" brakes, and Baer Brake rotor hats
These aren't normally sold in pieces like this (the 13 or 14" 6 piston baer kit will run about $2400)
All you would need are rotors and calipers
Looking to get $500 for the brackets, spindles, and hubs
Also have a 67-70 Mustang Rack and Pinion Complete steering setup - this was used for approx 800 miles (a summer and a half before I took my car off the road to change it) The new front clip I have includes a rack and so I have no use for this anymore
This comes with the power steering pump, and bracketry for a windsor based small block
Looking to get $800
As you can see I've priced things individually, but ideally a package deal would work best for me. All these parts together makes for a pretty sweet setup in a 67-70 Mustang - it bolts right in and can be removed or reversed if there was ever the desire to go back to stock.
Tom
Looking to get $800
Tom
