peter0851
07-02-2005, 11:56 AM
I am having a big problem with vibrations, I think it comes from the driveshaft or something in this area. I have tried the following.
Pinion angel set up and down are now at front 2 degree down and rear axel 3 degree down.
The driveshaft has been fully balanced and is straight and with new u-joint. I have tried two different complete rearaksel carrier.
The vibration is coming at around 4000 RPM in high gear (TH700 with lock up) and getting worse when I goes higher in RPM. The rear is 3,89-1.
Thanks Peter
:drive2:
Thanks Peter
:drive2:
