    Results 1 to 3 of 3
      Ocala, FL
      Soft Lip VS Stepped Lip. Any particular reason for either one?
      I have noticed many different wheel/tire combos today have a Soft Lip... versus the stepped lip. any particular reason for a Soft Lip over Stepped?
      Is this simply for looks or is there an engineering issue regarding bead retention under hard cornering? Or is there a tire/rim manuacturer that finds a soft lip more beneficial during manufacturing?
      I can understand if looks wise you dont want wheel weights showing, but for someone who has installed tires for a living...weights on the outer edges certainly makes balancing much more precise. I have always prefered clamp on weights versus stick on. Piece of mind IMO.
      Todd
      Sep 2007
      York, Pa
      Stepped lip is obviously the more traditional wheel style. What you are referring to as "soft lip" or "reversed lip" is for aesthetics. If you have an 18" step-lip wheel sitting next to an 18" "soft-lip" wheel, the "soft-lip style is going to look bigger because the wheel center is larger. also, the outer rim usually looks fatter/more dished because it is a large flat area. However, legit roadrace cars like ALMS run three piece wheels with a step-lip design probably because they are stronger. I also installed tires for a living and my opinion is clamp on wheel weights dont belong anywhere near high end wheels. OEM's use stick on weights now in a lot of applications.
      Justin Snow
      Lowell, MI
      It's an appearance thing. I love the reversed lip look myself just because it looks cleaner. Sometimes though, it's impossible to run a reverse lip wheel when a big brake/caliper is being used. The steeped lip generally allows for more room in the inside of the wheel.
      Turbo Charged LS1/T56
