View Full Version : LT1 fuse box
67 455 Bird ragtop
10-18-2011, 11:32 AM
I picked up a fuse/relay box from an 03 LT1 to use under the hood for extra relays/fuses. It has TONS of slots for fuses and relays. I know I'll never use all of them. So I was wondering. Should I completely strip out all the existing wires and only wire what I need?? Or try and trace each wire and solder connections as needed. My gut feeling says to strip it and just wire what I need.
TnBlkC230WZ
10-18-2011, 03:37 PM
The terminals are pretty cheap. If you are ok with crimping your own, I'd strip it out and start over. You may be able to reuse any buss bars in it.
67 455 Bird ragtop
10-19-2011, 09:28 AM
I have no problem crimping and soldering my own connections. But I can see where this might be a tedious task. At least I'll have someting to keep me busy over the christmas holiday ... LOL
TnBlkC230WZ
10-19-2011, 10:18 AM
It definitely takes some time. There is no real need to solder a properly crimped Metripack terminal. Make sure you have a good schematic before you start.
67 455 Bird ragtop
10-19-2011, 10:36 AM
Ok Thanks. I plan on buying a good quality crimper. And a good schematic is definitely a MUST. I think I'm in my 3rd itteration of all my dash/gauge connections.
TnBlkC230WZ
10-22-2011, 07:11 PM
I have a Visio of my dash wiring if you are interested.
67 455 Bird ragtop
10-24-2011, 09:04 AM
Thanks. That would probably be helpful. I'll pm you my email. PMs full
NoMoneyZ
10-26-2011, 03:56 PM
just a heads up, there is no 03 LT1. They were stopped in 97.
