Results 1 to 16 of 16
10-17-2011 #1
75 pin firemwall bulkhead connector
Only thing i can find is a $375 mill spec set-up. Im trying to pass a 07 ford harness thru a firewall but not break the bank. Digikey.com doesnt have the cheaper plastic bulkheads with a pin count that high. Any one know where I can source one?
Scotts Speed and Custom
norcal1320.com
10-17-2011 #2
- Join Date
- Feb 2007
- Location
- USA, TN
- Posts
- 850
It looks like Mouser carries the parts for the Delphi 78 pin connector. The Delphi site is down this evening so I can see the full configuration. All the part needed will be listed in the Delphi catalog or on the data sheet when the site is up.
http://www.mouser.com/Search/Product...yV%252bg%3d%3d
10-18-2011 #3that would work perfect if they had both sides of the plug- i need to find another delphi dealer and i would be in biusness- thanks
norcal1320.com
10-18-2011 #4
- Join Date
- Feb 2007
- Location
- USA, TN
- Posts
- 850
They have both sides. You'll need the part numbers to all the parts. You can down load the catalog from this link. You can also click on the data sheet from the Mouser site and view the drawings. You'll find part numbers for other components on the drawing as well.
http://connectors.delphi.com/DCSGDMC...adCatalog.aspx
10-18-2011 #5
