View Full Version : Power steering pump upgrade time
73RSZ28
10-16-2011, 06:46 AM
I'm installing my serpentine set up. The donor was a 93 chevy truck. My issue is now my original 73 camaro pump has a keyed shaft and my new pulley is a press fit. So I think it's time to upgrade pumps. I plan on running hydroboost brakes also so I need to keep that in mind. Any Suggestions?
exwestracer
10-16-2011, 08:00 AM
My only suggestion would be to find a pump application that was originally fitted with a box type steering and hydroboost... Mid 90s GM diesel pickup maybe?
SLO_Z28
10-16-2011, 01:54 PM
2500 and 3500 HD Silverados 99-07 had factory hydro boost optional. This uses the "type 2" gm pump too, which is better. You can get the parts necessary for this swap at KRC.
MCB Matt
10-20-2011, 01:50 PM
No need to worry about the hydroboost here...are you installing the complete serp setup from the 93 motor?
hessdawg
10-24-2011, 08:32 PM
im running a s10 ps pump
