    Results 1 to 2 of 2
      Oct 2007
      NC
      Wilwood calipers with outline of Wilwood in silver
      I have a set of front 6 piston Wilwood calipers in Red where only the outline of the word "Wilwood" is engraved in silver. I need to get rear brakes for a 9" new big ford housing 2.5" offset. I would prefer a 12.88" rotor and 4 piston calipers, but I need the "Wilwood" to match the front. All the kits I have seen have the entire name in silver, not just the outline. Any info or suggestions are appreciated.
      Name:  IM002062 (Medium).JPG
      Feb 2011
      CA
      I believe this style you have is the slightly older....the newest batches are the same but letters are completely colored and not just outlined. You may want to call Wilwood soon and see if they have an older set floating around the shop. Worst case, you can probably find a set doing just what you did....post up your wants and needs in different forums. Try the WTB in for sale section? Good luck.
