    Results 1 to 20 of 29
      Jul 2010
      the motor city
      70-78 Camaro second-gen gauge mounting solutions
      As promised, here is the GENII 70-78 Camaro gauge mounting solution we have been working on. The package mounts 2 3-3/8” gauges and 4 2-1/16” gauges in the stock location, retaining the stock turn signals switches and dash panel. The laser-cut and formed mount bolts to the factory mounting screws. The bracket is formed to follow the countour of the original dash.
      The only thing left to do is find a donor vehicle to test fitment and decide what to do with the stock shift indicator area. We have considered using one of our indicator panels in there to fill the void. Looking for input there.
      Thanks, look foreword to any input
      Mark
      Pricing for the basic mount should be around $100.00
      Mar 2010
      Clovis NM, 88101
      very nice. Too bad I already have the dash/bezel/gauges done.
      73 Camaro
      Gene
      Oct 2011
      Lost
      I may be upgrading my gauge set up. Yours is a good alternative if I decide not to go stock as the replacement....
      Oct 2006
      Morristown, NJ
      That looks great. I did something similar and wouldn't mind changing it out for a better fitting solution. When I did my homemade dash, I put in a high beam indicator and a brake indicator. Something like that would be nice in the center area. Maybe even a check engine light for people who converted to EFI.
      1973 Camaro Type LT/RS
      http://www.apiem.com/camaro
      Jul 2010
      the motor city
      I don't see why we couldn't use the stock shift indicator, but wecould also use one of our indicator panels, pretty slick setup. We can do shift indicators, warning lamps, turn signals, check engine, brake, etc, in any layout:
      Rightnow the issue is finalizing the design and getting proper fitment. We need to either get a car in here or have someone do some test fitting for us.
      Rustburg, Virginia
      May want to add the 5" Tach and Speedo to your lineup and 270° or more sweep for all of the gages. Lots of folks like the larger ones.(me included)
      Jul 2010
      the motor city
      Hi John
      We do have 5" speedo and tachs, they are too large for this particular application though as far as we can tell. The cases are wider that the stock support so I don't think they will fit. I won't know for sure until we can do a test fit
      Mark
      May 2009
      North Dakota
      Is this available yet? Would like to order some 1969 gauges for my 71.
      Jan 2010
      Somewhere out there
      Quote Originally Posted by John Wright View Post
      Agreed. Same here, I prefer full sweep gauges.
      Looks good though for the guys looking to keep the stock bezels.
      Jul 2010
      the motor city
      Hi all,
      We have had these comlete for some time, just had not gotten around to the part numbers, pricing and photos. Well, everything is ready to go 2 sizes to choose from, the 3-3/8" on the 69 and Redline Styles and 4-3/8" speedo/tach in the Performance. Kits include 6 gauge kit, panel, indicator, 0-90 fuel gauge, temp and pressure senders, bushings and instructions. Performance kits also include a GM sped sender, 69 and Redline may require a speed sender.
      Prices range from $659-$846 retail
      Here are the pics:
      Jul 2010
      the motor city
      A couple of install images to show the difference in the 3-3/8" and 4-3/8" speedos
      Also a pic of the indicator.
      One note, these are packages, the bracket is not available separately.
      Mark
      NYC
      x2 im with john
      Jul 2010
      the motor city
      Quote Originally Posted by $Mike70Z-28 View Post
      x2 im with john
      Both are available as custom builds
      69 and Redline are available in 4-3/8" speedo/tach as custom
      Performance are available in 4-3*8"
      Jan 2010
      Somewhere out there
      I'm having one HELL of a time deciding between the 1969 series and the Redline series for my 442.
      I sent you a PM.
      Jan 2011
      Middle TN
      Wow this looks really nice. I'm gonna have to replace my gauges at some point and this could be a viable option. Up till I saw this, I've figured I'd have to go with the Classic Dash which is 900 bucks. It's definitely not the prettiest at night but my truck needs a transmission so all my extra money has been going to that.
      73 Z28 Camaro. Bone stock except for TKO-600 road race 5 speed.
      Feb 2010
      NE Arkansas
      Interested, I have a 5.3 / 4L60e swap going in my 76 camaro. I was wondering if I can get this without the center indicator lights?
      Would I be able to reuse my stock center shifter indicator? I have a modified one That has the od indicator built in...going for an old school look. I want to put my high beam and check engine lights in another spot.
      My main reason for doing this is to go with a electronic speedo, right now I have my stock mech speedo and it won't work with my 2004 4L60e and planned on using a cable x box to bridge the gap....this would eliminate the added parts.
      My build thread
      http://www.nastyz28.com/forum/showthread.php?t=241037
      Paint Jail Experience
      https://sites.google.com/site/paintjail/home
      Jul 2010
      the motor city
      Yes yo can get it without the indicator but the original shift indicator will not work. We can always bui8ld an indicator for you that would have the functions you want
      Quote Originally Posted by 1976CamaroGuy View Post
      May 2009
      North Dakota
      Hey Mark,
      I finally got the 1969 Gauges installed in my 71 Camaro using your mounting kit. It worked pretty slick. The only reason it took so long was because once I pulled the old gauges out of the dash I decided a complete re-wire was in order. One thing, I cut an old piece of a tinted motorcycle helmet shield and glued it to the back of the bezel. You can still see the signal/warning lights through it when they are on otherwise it looks like the blacked out gear indicator from a manual trans car. The 1969's look like they belong in the car, they wont look outdated in 10 years.
      Cincinnati, OH
      Any chance you have a setup for the 79-81 Camaro? I'd really rather have this than the Covan's panel.
      Jul 2010
      the motor city
      The panel will fit physically but the indicator and turn signals will not line up. If we had a dash we could come up with something
    Tags for this Thread
