    Results 1 to 4 of 4
      Greeley, Colorado
      Which is better for looks and performance?
      I'm about ready to order wheels and tires for my Firebird. I'm looking to spend between 3000-4000 for the wheel and tire combo.
      I know I don't want anything larger than an 18" wheel. The question is which setup will be best for performance as well as looks.
      Option 1: 17" at all 4 corners
      Option 2: 17" front, 18" rear
      Option 3: 18" at all 4 corners
      I know they are around but I've never seen a first gen with a 17/18 combo.
      I will likely run an 8.5" with a 245 section width in the front. What aspect ratio should I run?
      I will run a 275 section width on a 9.5" wheel in the rear (not mini-tubed), again what aspect ratio? Can I run a larger section width?
      The wheels and tires will need to tuck inside the wheel wells. I'm lowering the car enough that this will be necessary.
      Car has stock drums in the back but will likely change to rear disks later on depending on how often I use the car for on-track events.
      Jason Mounce
      1969 Firebird | 2008 Corvette Z06 | 2008 Mustang GT/CS
      Greeley, Colorado
      Well I should have money by tomorrow. I think I've decided on 17" at all 4 corners. Likely will be going with Fikse FM10's. 17x8 front with 245/45/17 rubber, 17x9.5 rear with 275/40/17 rubber.
      Jason Mounce
      Oct 2003
      Arvada, Co
      Good choice. Just get your BS correct and you are good to go. I went with a 8.5 front with 255 tires.
      Brian
      I have an unlimited budget. That bad part is I have already used it up.
      Greeley, Colorado
      Quote Originally Posted by baz67
      you can fit a 8.5 with 255 rubber up front? I thought the largest you could go un-modified was 17x8 with 245 rubber. do you have rubbing issues?
      Do you think I could get a 285 tire on the rear?
      I'll be measuring back spacing on the car tonight so that I can hopefully get them ordered tomorrow.
      Jason Mounce
