    Results 1 to 5 of 5
      Jun 2006
      Katy,TX
      Lugcentric wheels-lugnut OD vs wheel ID
      So what do amount do most wheels that are lugcentric have larger than the lugnuts ? My ProStars are about 0.015. Figure you would need some for the variation in bolt circles between the wheel and hib and if the studs are not quite perpendicular.
      1978 Black Trans Am 455 Edelbrock heads [email protected] through mufflers on pump gas
      1981 Trans Am 400 stock type motor
      79 Camaro getting a 500" 695 hp IA2 Pontiac motor
      1965 GTO project car
      470ci/Chevy dual quad 409 604 HP 64 Impala SS project
      2004 Pulse Red GTO
      Jun 2006
      Katy,TX
      No body got a dial caliper??
      2004 Pulse Red GTO
      Oregon
      I don't understanding what are you measuring...are you referring to the conical seating surface of the lug nut versus the machined seat in the wheel? If so, then it will depend on the wheels and/or the lug nuts as they're not all the same.
      Wheel ID? Most of the wheel stud holes in aftermarket alloy wheels seem to measure about .600" to .625" diameter so long as they're not sized for 5/8" wheel studs. The 60 degree countersink depth varies, however it's not all that critical so long as the contact area is large enough to keep the contact stresses below the material yield strength. Similarly, the contact surface of the lug nut is almost irrelevant considering that the wheel contact surface is generally smaller.
      Tobin
      KORE3
      It's what I does.
      san diego
      Tobin,
      I think he is asking what is the hole diameter on lugcentric wheels (shank style lugnuts) and the diameter of the lugnuts.
      Oregon
      Bryce...thanks. That would make more sense that it would be a shank style mag lug nut. I'm not sure what the tolerances those are typically machined to and don't have any wheels to check, sorry.
      Tobin
      It's what I does.
