    Results 1 to 2 of 2
      Nov 2004
      Air Ride Tech Four Bar
      I have been looking at the air ride tech air 4 bar setup for my 68 camaro and I like the idea of ride height adjustability and the ease of install. My question is: Is this kit structural enough for my car which has a 406 small block with approx. 430- 450 horsepower? I will be building rectangular steel subframe conectors as well as rocker to framerail supports similar to musclerods. This car is being built mostly as a street driver with occational track and high speed cornering . Also what do you guys think about the shockwave camaro front setup? Will I be loosing subframe structuality when I make the cuttout for the proper air bag clearance? I know you guys will get me headed in the right direction with this project so any imput would be greatly appreciated. What are the pros and cons of these setups?
      THANKS A LOT!!!
      Nov 2004
      NW Arkansas
      I have not seen there set up for the camaro air ride stuff is usually decent....how much power are putting to the wheels you think? The shockwaves in the front will be great I woldn't worry about the small amount of front subframe material that you will loose! Find out what size the bars are for the sir ride stuff and what they use for adjustable ends I would say with your setup you need a johnny joint or a good heim! proper air bag clearance 1/2 through full travel of bag!
      KENNY DAVIS HOTRODS
