    Results 1 to 3 of 3
    Thread: Junction Block
      Feb 2009
      N.J.
      Junction Block
      Need some help from the electrical guru's here.
      Can I run this junction block off the battery to supply power for my a/c & dual fans?
      Or do I have to splice this into my battery to started wire?
      Thanks.
      First you need a copy of the instructions since it is our product. Next NEVER splice into the battery terminals for anything unless it is absolutely necessary or a very high amperage item like a winch, etc. These connections tend to corrode when taken from the battery. Our instructions should suggest that you take power off the battery terminal of the starter solenoid. You should feel free to ask us these questions to get the straight answers about products we make and design.
      Feb 2009
      N.J.
      You were getting a call this morning on this subject.
      Your directions don't say whether to connect it to the battery or the starter solenoid.
      So I guess it's the starter solenoid.
      Thanks for the info.
