Rols574
09-15-2011, 12:08 PM
I'll start with a warning:
It is a daily driver, updates will be slow to come by.
I also would like to state my goals with this car and I'm open to suggestions as you will see I'm undecided in a lot of major things, so if you can give advice I will certainly welcome it.
Here is what my car looks like as of today
49283
49284
It has rust issues in both the rear quarters behind the wheels, driver side door and driver side fender, also behind the wheel. This will be my daily / main car. I bought this car because I love the style, not to be sitting in a garage %99 percent of the time. Since it is a daily driver I plan on upgrading the basic safety aspects of the car first. I have ordered the Wilwoods 12" drilled and slotted brake kit. People have told me to avoid the drilled rotors because as is stated in the Wilwood website " A drilled rotor provides the same type of benefit, but is more susceptible to cracking under severe usage; however, for street and occasional light duty track use, they will work fine". Im more interested in the latter part since as I said it is a daily driver and I'm more interested in looks (I hope that didnt turn some of you off:guilty:) I had to get bigger wheels because the rotors would not fit with the Cragars I have on now. So I got these 17x8" wheels
49282
Since I may not be the only driver the Wilwood Tech suggested i get the 7/8" bore master cylinder. Im having some electrical gremlins and instead of trying to bandaid the problems I would like to slowly transfer the electrical harness to an ISIS system. I talked to Jay from ISIS and he said that it was possible to transfer the basic functions to an ISIS over weekend projects (ie. tail lights one weekend head lights another and so one)
So that's what being done in the immediate future. now come the questions and where I'm completely open to suggestions.
Since it is a daily driver my main concern is MPG but I would ideally like to be in the 400HP range and have 20+ MPG. Im not sure any of the Ford pushrod engines get me there (please correct me if I'm wrong). The new Coyote engine can get me there but I would have to do so by messing around with the shock towers (but I really like this engine). I really dislike the MII suspension (again aesthetics) and Grigg's is a little steep in the wallet. I'm kinda leaning towards the Struts from Gateway Performance but again I have to notch the towers. Another option could be an LSx motor. I hear they are smaller and MAY fit without having to touch the towers at all (can anyone confirm?). In the rear I'm leaning towards the g-Bar TCP system.
Kinda long winded so I'll keep the rest for another time. Please do chip in with your opinions.
49283
49284
49282
