    Results 1 to 3 of 3
      May 2011
      Country Flag: France
      engine start button, can't find the wire to use to wire it up
      Hello Guys, maybe someone can shime in and point me in the right direction, here is the deal:
      The instruction for this universal start button tells me to find the two wires that connect to the silenoid, do you guys know where I can find them on the car ?
      The wiring harnees from the column goes to two different relays look alike are those for the starter?
      I looked inthe haynes manual but they only point out a yellow wire!
      Please any help would be appreciated.
      Thanks in advance
      Ben
      Rustburg, Virginia
      How many terminals does this start button have? I ask because you didn't say whether it is just a starter switch or if it has an ignition postion also.
      May 2011
      Sorry, it would have helped a bit!
      It a starter button only, the push button got to prongs one for 12v ignition power the other back to a 4 prong relay,
      Out of the relay, one ground, the other for 12v and the other two big wires to the supposed to be 2 wires for starter?
      Hope it is clear enough for your understanding?
