View Full Version : G-Body Engine Swap Question
LS1Regal
06-27-2005, 11:09 AM
I need help again....I have plans to install a LS1 into a Buick Regal. Now my original plans were to use a Corvette LS1. I have had alot of people tell me that the Corvette LS1 won't work in a Regal and that I have to use a Camaro, Firebird LS1. If this is true, what are the horsepower difference's between the two?
Bill Howell
06-27-2005, 03:07 PM
Someone correct me if I am wrong but I would think the only difference between a corvette ls1 and a camaro ls1 on the exterior would be the oil pan. :dunno: As for hp difference, I think if you had two ls1's, one from a camaro and one from a vette, both had indentical headers, cam, throttle body, etc, there would be very little difference.
oil pan and accessory brackets are the only differences that would cause a fitment issue. of course the exhaust manifolds could be an issue as well. you will probrably want to use fbody engine mounts. use a later style fuel rail and you want need to run a return line to the fuel tank.
LS1Regal
06-27-2005, 07:09 PM
I appreciate all of the help, as soon as the project is under way I will keep everyone updated.
ProjectJ
06-29-2005, 08:05 AM
TD Performance recently came out with adapter mounts to adapt factory mount/pad to the LS1 engines (check them out HERE (http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=964&prmenbr=361&ct=103)). They would probably simplify getting the engine in the car at least... when it comes to exhaust, that might be some work.
dgumoe
06-29-2005, 01:04 PM
also check out john bzdel's website. he was one of the first guys i saw that put an ls1 and six speed in a monte ss and his execution of the project was spot on. home.earthlink.net/~bzdel/
