View Full Version : lowering springs
mattdirocz
08-26-2011, 10:48 PM
ok put on my lowering springs and now my car is sitting on the lower bump stops. How does does this sound to other lpeople. my buddy says his car sits the same way. just curious. also my sway bar end link sleeves will need a decent amount of trimming to be level not sure if i like all this love the look of the car tho.
https://static1.pt-content.com/images/pt/2011/08/20110822124702-1.jpg
Rod
08-26-2011, 11:17 PM
?? hard to see any better pictures? before and after?
mattdirocz
08-27-2011, 06:39 AM
BEFORE
https://static1.pt-content.com/images/noimg.gif[/IMG]
AFTER
https://static1.pt-content.com/images/pt/2011/08/20110820110931-2.jpg
https://static1.pt-content.com/images/pt/2011/08/20110827093645-1.jpg
ROBS6T8
08-27-2011, 04:08 PM
Wow, that is a bit lower! What springs?
mattdirocz
08-27-2011, 04:13 PM
3" drop with half coil cut off
dhutton
08-28-2011, 04:53 AM
Maybe you went too far. Ride quality riding on the bumpstops will likely be a tad harsh....
mattdirocz
08-29-2011, 08:57 AM
Yea think i got some things to figure out like what springs to buy next any one out there got a pic of a 67 68 camaro with c5 wheels and 2 inch or 3 inch drop springs.
wmhjr
08-29-2011, 10:16 AM
You're trying to drop height by only changing springs, correct? JMHO, but if you end up just buying springs, you're probably going to end up with a combo that you'll end up having to change springs again in order to truly correct geometry problems.
speedy79
08-29-2011, 11:22 AM
All my lowering experience comes from lowering trucks, but my best experience with ride and handling after lowering has been using drop spindles in combination with drop springs.
