    Results 1 to 20 of 21
    Thread: Vented hood?
      Apr 2011
      Ewing, NJ
      Vented hood?
      Can someone school me or link me to information about properly venting the hood on a 99 Camaro?
      I can get a hood for free to play with and I would like to fab a vented hood to drop to drop the pressure and keep the front of the car planted at speed. Maybe I am using the wrong word combinations but I haven't really found much useful information online.
      I will be doing the work in my garage so it won't be anything too fancy. Just need basic info about placement and sizing.
      -Thanks
      -Tim
      NJSPEEDER - Tim Mullaney
      New Jersey F-body Owners Association
      www.NJFBOA.org
      NJ's home for all owners, friends, and fans of Camaros and Firebirds
      Dec 2008
      Lehigh Valley Pa
      There is an aerodynamics thread that tels you completely how to test for it and everything you need to know. I will be venting my hood as well. But it needs to run to test it. That and I have yet to find the perfect vents. Also not that keen on cutting into my rare aluminum hood until I can find a spare just incase I screw up.
      1996 Federal Cadillac hearse
      1988 Eureka Chevy hearse
      Dec 2008
      Lehigh Valley Pa
      Apr 2011
      Ewing, NJ
      Thanks a ton. Huge help.
      Yeah, I wouldn't chop up an aluminum hood either. The advantage of having late model junk, you can find about any panel you need for free or damn close.
      -Tim
      www.NJFBOA.org
      Sep 2004
      savannah,ga
      One option for hood vents is to have louvers punched into flat panels and then graft them to the hood, or check out a marine supply store like West Marine, they sell stainless louvers for venting engine compartments on boats, they look good, too.
      Jul 2009
      Grand Rapids, MI
      Another option is to use a fiberglass hood and find a production vehicle whose scoop/vents you like and have that molded to the glass hood. If the scoop/vents are not 'glass themselves, use a steel hood and weld them in. That's what I'm doing. Took a 'glass Dart hood and am having a viper scoop/vents molded to it.
      Will Ellis
      Build Thread
      Aug 2006
      San Francisco, CA
      Quote Originally Posted by wellis77 View Post
      Awesome to see someone grafting the Viper Louvers into a hood...I am planning on doing this to my 68 some day.
      Steven
      1968 Camaro: Project "TRACKDAY"
      Latest Track Weekend Video
      Build in Progress
      Jul 2009
      Grand Rapids, MI
      The Viper louvers are hot and they can work with many different scoops, I think.
      Will Ellis
      Build Thread
      Nov 2009
      the dirty mitten
      Sure does look awesome Will. Any word if that guy is going to be making copies of that Viper hood for others to use?
      Steve
      Jul 2009
      Grand Rapids, MI
      Yes he is going to pull a mold from it. If I'm not mistaken, he is doing B & E bodies as well, not sure which ones though. If interested, send me a PM and I'll get you his number.
      Will Ellis
      Build Thread
      Red Deer, Alberta, Canada
      Anyone have sources for a production vent? I know the jeep guys have some, but they are rather crude looking. Ive also seen some local import guys following the the cut outs under the hood(if you open your hood, the pockets that not part of the support layer), then using mesh to fill it in. hmmm
      Matt
      Instagram: Cst_koon
      Mar 2010
      West Tennessee
      Vented Hood
      Check out Anvil Auto hood vents. They may make something to fit your car. The ones with the screen vents look especially cool!
      Matt, Factory 94-97 Pontiac GTP vents w/drip trays and 91-94 Chevy lumina Z34 vents w/ drip trays are common swaps and look pretty good. VIS Universal scoops.
      Tim, Don't know if you knew, but they make CF hoods for the 4th gens. The AMS is a really good deal.
      Newest design VIS "SCV": $1,100.00 from VIS Racing
      Vis "AMS": $744.60 from Andy's Auto Sport
      Fiberglass vented fenders, never seen these for the F-body. Both 3rd and 4th gen. $178.62
      Will, your hood is jaw dropping.
      You can't be slick to a can of oil
      Jul 2011
      SoCal
      Isnt it better to vent the fenders than the hood?
      Dec 2008
      Lehigh Valley Pa
      Quote Originally Posted by HI! View Post
      To be truthful it should be tested. Check out the links I posted in post #3. It is possible you can make things worse with an ill placed vent.
      Indeed, I highly doubt the fenders are ever tested for aerodynamics. Their all just copy and paste designs of existing aftermarket import fenders or Lorinser fenders. Mainly posted the vents due to speculative weight savings for the track/strip camaro and the "looks cool" factor
      Sep 2011
      Southlake, TX
      We've run the 90's Pontiac GP vents on our hood for 14 years now and they work excellent. I used a Dremel sanding drum to remove the casting flash in the openings and open them up for more flow, but you can't really tell from the outside.
      Here are some pictures of the top and underside of our GP vents:
      You can literaly see the heat coming out of them. We run a ZZ502 and have covered over the top grill opening for aerodynamics, but the motor stays @ 160 under the worst conditions and there is zero rise of the car nose at speed.
      For location on the hood, you want the place with the highest velocity air flowing over it and the largest plenum of air under it. Air slows down at the center of the hood as you go towards the windshield, but has to speed up to break over the fenders or around the sides of the windshield... so middle, forward of the motor is good, as is the sides of the motor as you go back. A vent right above a shock tower, AC box or inner fender won't be as effective as one above the headers where there is less resistance to air movement under the hood.
      Chris Bischof
      My G-body homepage
      '86 Pontiac 2+2 ORR car, '86 Regal T-type, '86 GN, '89 TTA, '13 GTHIG 5.0
      SORC 115 mph Class Winner '07, '10, '11, '13, '15
      Jul 2011
      SoCal
      The articals in the links were great for forward airscoop stuff. Im thinking Ive seen alot of GT cars with vents in the fender sides, plus some had the radiator vented on its own. I believe that was the chevys L88 original hood design.
      Its interesting to say the least.
      Oct 2011
      kcmo
      Quote Originally Posted by protour_chevelle View Post
      and this is how I did mine. my SN95 has a 5.4 out of a GT500 complete with the supercharger and all. the engine bay is almost too small for this engine and has created a high pressure spot behind the radiator and in front of the motor. only ran hot with the hood on! now with the vents in place it runs cool and clean. I added gurney flaps to the leading edges of the openings to create even more low pressure at the vents.
      Apr 2011
      Ewing, NJ
      Do you have any close ups of how the vents are set in the hood? Definitely a good looking mod from your pics.
      www.NJFBOA.org
