    Results 1 to 18 of 18
      Jul 2011
      Gerogetown ky
      What should I get for a/c ???
      I have a 69 Camaro hard top non a/c car I live in Kentucky. I want a/c
      So the female will enjoy the car more an it would just be nice ;). But what should I go with am about to redone my body an paint so I would like to do the install when am putting to car back together. The motor will be an ls1 from a 2000 Camaro it will have the power steering pump an alternator with stock water pump an a underdrive crank pulley (asp). If anyone could tell me any info it would help I see that vintage air Is a sponsor on here an I seen people been doing the vintage air Gen 4 in some of the Camaro's but don't know if that's the best kit for me r would work for me.
      Thanks jason
      Nov 2009
      Prior Lake, MN
      Vintage air rocks
      "A parent's only as good as their dumbest kid. If one wins a Nobel Prize but the other gets robbed by a hooker, you failed."
      Jul 2011
      Gerogetown ky
      That's what I heard
      Indiana
      Nashville, TN...98 degrees at the hotrod power tour...waiting in the staging lanes at the autocross...with the engine and the A/C running...guy comes up and says..." afraid it wont start if you shut it off?" "nope...just got the A/C on to keep nice and cool!"
      48 degrees comng out of the vents [according to my handy tire temp guage that I was playing with at the time]
      Vintage Air...there is no substitute!
      Bret Voelkel
      Director of Innovation Fox Powered Vehicles Group
      Founder/ Former Owner
      RideTech/Air Ride Technologies, Inc.
      How do you spell Impossible?
      Jul 2011
      Gerogetown ky
      What kit do u have?
      Quote Originally Posted by bret View Post
      Dec 2010
      St Louis
      I put the Vintage Air gen 4 kit in my LS powered 68 corvette. They worked with me on the LS related parts. I think they offer the Kwik bracket for drivers side top compressor mount. It fit great, they were a terrific company to work with with on the LS replacement parts. Buy from a local disributor if you can, their shipping costs on small parts (ie trinary switch) can be expensive.
      I just put Classic Auto air in my LS powered 72 Olds 442. No one offered a direct fit kit and I knew I would be mofifying a lot of stuff , so I went with the simpler cable operated kit from Classic. They were great to deal with too, they swapped out a lot of parts at no cost. They even offer the Kwik bracket at half price.
      Both great companies with great products.
      Sep 2010
      Beach Park IL
      Vintage Air, no question...
      Aug 2003
      Orlando, FL
      Vintage Air Gen IV. The only OEM quality A/C avaialbe for retro fit into old cars
      Aug 2010
      S. FL
      Totally agree Vintage Air Gen IV. Nice, complete kit.
      Options available to make it very custom, or install as is.
      Greg
      1969 Camaro Vert RS SS
      McKinney, TX
      Vintage Air, although I had some issues with mine such as the power switch to the compressor clutch was routed through the stock fan switch and burnt up my contacts. A simple relay and contact cleaning fixed it. Also, one of the hose crimped connections going into the dryer loosened up and leaked fluid. It still works like a champ to this day.
      89 Mustang "Box Wine"
      Jul 2011
      Gerogetown ky
      Quote Originally Posted by ProdigyCustoms View Post
      Well frank u sell thoses too! If so that's great I can just get all my stuff from u lol am trying to get all that I need so I know how much of a loan to get
      Jul 2011
      Gerogetown ky
      anyone have storys about their vintage air gen 4 they like to tell me about the pro's an con's an what would u do all over again...
      thanks jason
      Aug 2010
      S. FL
      You cannot bundle the white power wire with any other wire or risk unwanted electro magnetic interference getting into the VA cpu, which will cause crazy things like hyper relay chatter. I did bundle and buttoned up in a fender before realizing I had a problem. I had to abandon the original supply feed and run a new isolated power feed.
      That's the only con I found with the whole system, that the cpu power supply circuit has not undergone too much R&D in the EMI/isolation/shielding/protection front.
      Greg
      Sep 2009
      Iowa
      Quote Originally Posted by 69blackwhss View Post
      thanks jason
      In the middle of installing a Gen IV kit in my wife's 69. (hardtop, non a/c, flushed firewall) I'm doing the extended hose deal through the fender/vent hole. We have a March accessory drive system with the compressor on the passenger side which made routing the hoses easier. Not using any bulkhead fittings also reduces the number of connections. I’m using DSE's bracket which is handy for taking the unit on and off while fitting up everything.
      I just got the refrigerant hoses crimped by the parts store yesterday and all the hoses installed last night. I am going to start wiring tonight and hope to get it charged up by Friday. (it’s been nasty hot lately) No heat/ac controls came with the car so we are using the vertical 3 knob control which is a quality piece. We have a Covan dash with a blank area to the right of the steering wheel so it fits nice.
      Only problem I've ran into is with the wiper motor. When the guy before us flushed the firewall he hid the motor under the dash. The hose box/adapter deal for the driver, center, and passenger vents hit it. That part is removable so I'm working on fabing up a different shaped piece to get the job done.
      My kit didn’t come with the coolant/heater hose but it’s readily available at the parts store. The instructions could be more informative for a newb but there are enough details to get the job done.
      Good luck!
      //Ed
      //1964 Impala SS
      //1972 C10
      //1969 Camaro (hers...)
      Jul 2011
      Gerogetown ky
      Thanks for all that info hope she will enjoy her Camaro Agee u do all that for her lol
      Jul 2011
      Milford, CT
      There are lots of good deals on e-bay on GEN IV kits for the First GEN Camaro. You should check it out there 69blackwhss.
      Jul 2011
      Gerogetown ky
      Quote Originally Posted by l_and_t_reproductions View Post
      Ok thanks
      don't drive faster then ur angels can fly!
      Auburn, CA
      I'm sure that eBay has good deals but they don't always have the support that a Prodigy Customs (for example) will have before and after the sale.
      Even if you find a really aggressive price, try checking with the forum sponsors first. You might be surprised what they can do for you.
      Just me but I like to try and support those who support us.
      Tim Tracy
