    Results 1 to 5 of 5
      Oct 2003
      South Lyon, MI
      Front Brake Hard Lines - what to do
      What are people using for hard lines in the front in a 4 wheel disc brake set-up. I have a 69 camaro with Baer 4 wheel disc brakes. I was planning on running the stock front to rear line (2 piece) with the adjustable proportional valve spliced in. I'm not sure about the front lines. Bending lines is not one of my skills.
      Kevin
      Bedford TX
      Inline tube sells all the hard lines you could want. Pre bent and flared just for you.
      Justin, 68 Camaro Update:5 speed is in and neighbors are pissed!
      Oct 2003
      South Lyon, MI
      68Bnut,
      Talked to Inline Tube, they are local to me so I would like to purchase from them. They recommended the Power Drum Brake lines if I want to install an adjustable proportional valve. After I looked up the kit, I can't figure out why the front line kit has 4 pieces. Any idea?
      Kevin
      Houston tx
      I got them from another company, but my kit had 4 because two of them were the short ones that run from the master cylinder to that block mounted below it.
      Bedford TX
      Yeah that would seem right. I had the 2 curly" lines from master cylinder to distribution block then from there 2 more lines that go out to each wheel.
