    Results 1 to 2 of 2
      67 Convertible f-body exhaust system for 3" Mini-Tub??
      Not sure where to post this but since its its suspension related... I'm finishing up on a 3" DSE mini-tub kit w/ 335's in the rear on a 67 F-body CONVERTIBLE. I purchased a Rock Valley narrowed gas tank and relocated(inward) shackles and 3" drop springs. Room is pretty tight it seems. 4 questions:
      - Is there a kit that works well with 3" Mini-Tub kits and avoids clearance issues???
      - What size exhaust pipes do you guys recommend for my setup- 2.5" or 3" piping??
      - Also, on a convertible I know shimming the X-brace under the car is required for most 2.5" exhaust pipes...but can it be shimmed and still offer proper support to accomodate 3" exhaust pipes as well??
      - Lastly, Can I simply remove the X-brace. I'm running the DSE subframe connectors and using their crossmember brace which should add rigidity but being that its a Convertible I'm still a little weary of removing it completely.
      BTW, car is mostly for street...but for occasional strip/racing use. 550 horse power and no roll cage.
      Thanks, Chris
      Niceville, Florida 32578
      At that power level I'd recommend a 3" system. You can run 3" down the tunnel if you add some spacers to the crossbrace. I used a custom system from Dr Gas and a home made spacer.
      Dr Gas
      You can also buy the system and spacer from Pypes.
      Pypes systems
      All that is necessary for evil to succeed is that good men do nothing.
      Edmund Burke
