View Full Version : Megasquirt II
xx_ED_xx
07-08-2011, 07:11 AM
Sold
aronhk_md
07-08-2011, 09:10 PM
Is this one sequential injection? Didnt see it mentioned so not sure.
xx_ED_xx
07-09-2011, 04:55 AM
That is the ms3 extra which is 3 times as much
aronhk_md
07-09-2011, 05:38 AM
figures.....champagne taste, beer budget. LOL. Mentally adding up what yours would take me to do. I'd need rails, sensors, new pump and to get my freshly polished intake drilled. The pump and the intake would be expensive for my car, trying to think what else. I need to go look at their website.
Is the pic your setup currently or is that before you installed it on your truck?
xx_ED_xx
07-09-2011, 05:51 AM
Is it on the poncho?
aronhk_md
07-09-2011, 05:16 PM
Yes, for my 73 turbocharged TA...The BEAST. Would love to go injected, but the expense right now seems quite high when I have spent so much elsewhere.
xx_ED_xx
07-09-2011, 05:17 PM
What are you currently running igniton and fuel wise
aronhk_md
07-09-2011, 05:38 PM
I have a Mallory Hyfire VI. The pump is an A1000, and the carb is a CSU blow thru 830. The pump is sufficient for blow thru use, but not for injection. I was at 1064 hp with that at 15 psi. With my hew heads, cam, turbo etc I will likely be at 1200 hp if not over. So a pump upgrade in my category isnt a cheap proposition. Probably would need a pump controller too. And of course more expensive injectors. Really would love to just twist the key though and have her fire.
trmexrunner
07-13-2011, 11:30 AM
so this is the prebuilt unit by diy. it comes with the usb adapter com cable? how about the pigtail harness to the motor you have pictured? its up and running currently on your truck do you have a datalog? so i could look it over and check the function of everything is it running coilpacks or just a single coil dist. the tables are 16x16 correct your description says 12x12 also any picks of the board itself front and back.
xx_ED_xx
07-13-2011, 05:40 PM
Yes it is. I dont trust my cheap soldering iron that well. I have the com cable you need a usb to com cable they are like 30 bucks new.the box is actually just contolling fuel. I am using a msd ls1 box for spark. You can have the box upgrade to run an ls1 or it will run hei and various other ignition standards in current config. Sure I can send a datalog email me at [email protected]
trmexrunner
07-15-2011, 08:53 AM
paypal sent
xx_ED_xx
07-15-2011, 12:59 PM
rcvd and sent Thanks
