    Results 1 to 3 of 3
      Jun 2005
      Stillwater Ok
      Bigger disc brakes and spindles
      I have a 85 chevy caprice can I swap out the spindles and rotors on to my 74 pontiac ventura? and what mods will I have to make? I am trying to make improvements to my car using what I have. Thanks,Cliff
      Prescott Arizona
      Sorry Cliff, the Caprice is front steer and the spindles are comparable to '70-81 Camaros and '75 up Novas(including the other GM versions). Your Ventura uses the older rear steer style that is comparable to the '67-69 Camaros. The good new is that if you have the coin you could use ATS' new spindle! I know what you mean about trying to use what you have, but in this case it won't work.
      Brian D
      Snotty Bimmer driver.
      Jun 2005
      Stillwater Ok
      Thanks Brian I will pull them off and save them.
      Cliff
