    Results 1 to 4 of 4
      Jul 2010
      Yet Another BMW/Trans Am Wheel Question
      Okay, I did some searching and research but thought I'd ask to see if anyone had tried this. I found some sharp BMW wheels online for cheap:
      Rare BMW X5 high performance offset tires and wheels. Great Shape besides a little bit of peeling on the inside if you look closely. Tire sizes -- front - 255/50 R 19 ---- rear - 285/45 R 19 V
      I'm wondering if they'll work on my 81 Trans Am with stock breaks, etc. I realize I'll have to go grab them and try it but ya' never know. Someone may know an X5 or a 19 inch combo won't work and save me some time.
      Paine
      Oct 2010
      Santa Ana, CA
      i put 745li wheels on my old chevelle not the same wheels but same bolt battern and almost the same off set, the do fit but in some cases u need spacers to keep them from rubing in the inner fender
      Havii Gonzalez, OC Calif.
      68' MARO - UNDER FULL RESTO - LSX ect..
      Used to be known as stilo
      Birmingham, AL
      Not sure about the offset on the X5 wheels. The tires are going to be pretty big around with a 19 inch diameter and 45/50 sidewall height.
      Stephen
      Jan 2010
      Delaware
      there are several threads on BMW wheels here...do a search. Dont think the BS on the X5 wheels works for most. For my 2nd gen it was the 5 & 7 series wheels that work. You'll need the hubcentric rings, and MAKE SURE the hub size is the correct one. One of my previous posts has all this info.....I have the Rondal BMW wheels going on my 2nd gen bird
      1973 Trans Am 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods, 77mm Garrett turbo and methanol injection. 1064hp at the flywheel@5500 rpm
