View Full Version : Rear Spring Pad Necessary?
Drewhelm
06-20-2005, 01:22 PM
I'm using a 8.5 10 bolt rear in my 69 Firebird which has the universal type spring perches welded on and 2 u-bolts going over the rear axle and through the original shock plate. When I first assembled this I used the rubber multileaf spring pads, but they seem to have split. To I "NEED" a spring pad between the persh and the spring or can I make a solid mount without the pad?
Thanks!
Drew
Drewhelm
06-20-2005, 01:39 PM
After sifting through about 3 pages of historic threads I found they are not absolutely necessary.....guess I'll pull them out tomorrow night.
D
06-20-2005, 09:13 PM
ahhh no
06-20-2005, 10:53 PM
With that type perch no pad should be used!
Nine Ball
06-21-2005, 04:36 AM
I ditched those rubber leaf pads a long time ago. After doing a few hard launches at the track, they would split and make my axle get out of line. Tossed those suckers and never looked back!
Tony
Drewhelm
06-21-2005, 05:37 AM
Thanks! Exactly what I needed to know!
I guess playing the other night breaking in the new 2800 stall converted split the pads. ;)
http://firstgenfirebird.org/show/closeup.mv?CarID=642
