    Results 1 to 8 of 8
      Jun 2010
      Arroyo Grande, Ca
      Need my electric fan to turn on when AC is on?
      Just installed a electric fan and dont know how to hook up the AC comp. to the fan
      i think i have the Binary switch at the high pressure line do i tap into that?
      Jun 2001
      Orlando, FL
      Surf,
      That's the simplest way. Use the wire from the binary switch that goes to the compressor to power the fan relay.
      ​John Parsons
      Jun 2001
      Orlando, FL
      BTW, I deleted your other thread, moved this one to the A/C section and left a permanent redirect here in the Wiring section. That way your question is visible in both places, but there's only thread.
      ​John Parsons
      Sep 2010
      Beach Park IL
      You really should have a trinary switch. If you wire the relay to the compressor then the fan is running while you're doing 70 miles an hour for no reason. I have been told it's not good for the fan for that to happen but can't confirm it.
      That said, we have done them both ways I just prefer and recommend the trinary switch
      Dec 2010
      St Louis
      Trinary switch in both my conversions, that's exactly what it's made for.
      Jun 2001
      Orlando, FL
      I also prefer a trinary switch. It's really the better method, especially with electric fans.
      ​John Parsons
      Rustburg, Virginia
      with air being forced through it...it may be forced to turn in the wrong direction, which would not be good for the fan motor if it is "on".
      Caledonia, MI
      I'm running this and like it so far. It's made by a small company local to me. If you order you need to let them know that you plan on using your ac as a trigger.
      http://cgi.ebay.com/ebaymotors/ws/eB...STRK:MESELX:IT
      Jason Mitchell
      1969 Camaro @ Dutchboys
