Results 1 to 20 of 21
05-22-2011 #1
- Join Date
- Feb 2007
- Location
- USA, TN
- Posts
- 850
Controlling the fan with GMPP ECU
I have an LS3 eRod engine and ECU. The car also has a Vintage Air gen IV system with a trinary switch installed. I can't find and input for the GMPP ECU to tell when the AC is running. My dillema is; how to tell the ECU to switch on the fan. Should I just tap into the the fan relay that's in the GMPP fuse panel. If so, do I trigger it on the ground or positive side of the relay?
Is it possible the engine senses the extra load and turns on the fan when the AC is on?
