View Full Version : L92 not fitting in frame any help?
robertjra
05-20-2011, 04:59 PM
so i have a l92 and im puting it into my stock subframe in a 69 camaro i got the trans dapt 1" set back mounts the right side fits fine and the drivers side is an inch away from fitting.... so i made plates under the frame mounts out of 1/2" steel now the mounts are alot closer is this normal?
Z06vet
05-20-2011, 06:09 PM
Do you have any pics? What motor mounts are you using with the transdapt plates?
robertjra
05-20-2011, 06:29 PM
i have pics but my phone will not up load (it driving me crazy) the kit came with mounts in it and the frame mounts came from summit
prt# gmk-4020-335-69L and gmk-4020-335-69R
robertjra
05-20-2011, 06:36 PM
https://static1.pt-content.com/images/pt/2011/05/249010_217615691590266_100000255100572_8-1.jpg
ok got it this is my prob!
robertjra
05-20-2011, 06:42 PM
https://static1.pt-content.com/images/pt/2011/05/226267_217628071589028_100000255100572_8-1.jpg
this is the plates i made it works now but like i said i dont like fabing everything!
https://static1.pt-content.com/images/pt/2011/05/249868_217628048255697_100000255100572_8-1.jpg
this is the drivers side
05-20-2011, 07:10 PM
those look pretty short for SBC mounts...BBC perhaps?
robertjra
05-20-2011, 07:27 PM
thats what i think i told summit i needed 350 mounts and this is what i got i will call and see if any one elce can help me find the ones i need
TnBlkC230WZ
05-20-2011, 08:11 PM
The looks like short engine stands and motor mounts for tall stands. My Transdapt adapters had motor mounts for tall engine stands. You need to either get a set of motor mounts for short engine stands or get tall stands to work with the motor mounts you have. The correct motor mounts will fit snuggly on the stands. Those mounts probably have about a 1/4 inch gap.
robertjra
05-20-2011, 08:15 PM
ya they do!!! so i can call up NAPA and get mounts for a big block? and all will work fine.
Rod
05-20-2011, 08:52 PM
yes those are BB frame mounts
robertjra
05-20-2011, 09:10 PM
Well that's what I will do thank you every one this helps so much! I will keep you all posted.
05-26-2011, 07:50 PM
no you should get the proper small block chevy frame mounts/ frame perches. They sit up a bit higher.
