Results 1 to 14 of 14
Thread: Electric fan soft start circuit?
06-18-2005 #1
Full Blown G-Machiner
- Join Date
- Nov 2004
- Location
- Roanoke, VA
- Posts
- 515
First off if this is in the wrong section feel free to move it.
I remember seeing a post/advertisement on here a while back where someone was selling a nice/adjustable "soft start" system for engine cooling fans but for the life of me I cant find it now (yes, I did multiple searches).
Can someone post a link or the company thats making them? TIA
GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
#614 11.9 @ 113
New stuff finished 08/06:
4L80E trans w/TCI PCM
Front: J&S UCA/LCA, QA1 coil overs
Rear: Caltracks/Belltech drop leaves
Empire drive line alum drive shaft
Polished 17x9 F/17x11 R ZR1s with 275s/315s
Syclone
Tow rig
06-18-2005 #2Could it be the http://www.dccontrol.com/ cotroller you are lookin for? This is the one I am using, basically it slowly "ramps" fan speed up & down, not just on & off. I have mine hooked up to a Mark VIII fan, works good. If this is what you are looking for contact Gmachinz from this site.
HTHDean
69 Camaro 355-3.73 Moser Truetrac-TKO600-Hotchkis-DSE-QA1's-Baer's-17"Budnik's
ST U/LCA's-GW Del-a-lum's-Lee p/s
06-18-2005 #3
- Join Date
- Nov 2004
- Location
- Roanoke, VA
- Posts
- 515
Yep, thats the one. Thanks for the help
#614 11.9 @ 113
Syclone
Tow rig
06-18-2005 #4
06-18-2005 #5Dan,
Although it dosen't hurt to upgrade your alternator, I was told you can use your current one due to the fact that the controller does not require alot of voltage.
It is wired direct to the battey and not the charge post of the alternator. With that said I went with a CS alternator at the same time I changed my fan setup.Dean
06-18-2005 #6FWIW, I just installed one of the new Spal FAN-PWM adjustable controllers, you can adjust both low (50%) & high (100%) speed independently, as well as controlling multiple fans. An A/C input is included as well.
The thing I liked best was that it hooks up to your existing temperature sending unit, instead of requiring an additional bung/sender.
Mine came from www.streetortrack.com. It's so new that they may not have it on the webpage yet.
06-19-2005 #7The new Spal system looks nice, too. The main difference is that the DC Controller constantly varies fan speed to changing coolant conditions which is nice and, it allows for temp. changes with under-drive pulleys, AC usage and jumpers for lowering or raising the set-points at which the fan will kick on-sort of a band-aid for those with inadequate radiators/cooling fan designs. Also, you have to have an electric fan capable of cooling anything to take full advantage of any aftermarket controller-that's what makes the Mark VIII fan so attractive-it's just the best imo. -Jabin
Gmachinz Sales and Performance
"updating the level of performance..."
[email protected]
*never argue with an idiot-they'll drag you down to their level and beat you with experience!*
04-14-2006 #8
- Join Date
- Apr 2006
- Location
- Des Moines, IA
- Posts
- 602
