    Results 1 to 8 of 8
      May 2011
      Standish, Maine
      What size tires should I go with?
      Hey people,
      They'll be going on my 70 Chevelle with Hotchkis springs/1" lower than factory.
      What do you suggest/recommend? Maybe 275/40R17?
      Diameter 17" Width 9" Backspacing 5"
      San Antonio, TX
      I would use the 275/40/17.
      I assume you are going the same on all 4 corners ?
      Dave
      Oct 2009
      Sleepy Hollow,IL
      I would run a set of Nitto NT 05. If You can't do 275/40/17 all the way around,245/40/17 on the fronts would look good.
      Everything Under the Sun is Intune
      Chris
      http://www.popularhotrodding.com/fea..._am/index.html
      May 2011
      Standish, Maine
      Quote Originally Posted by mc84_zz4 View Post
      Yes, I'm going with the same on all four.
      Jan 2009
      Hermosa Beach, CA
      275 too narrow for such a big car, run a 295. Better stance, better traction, and rear brakes less likely to lock up.
      Pete
      1968 Camaro
      2009 Porsche 911 Carrera S
      http://www.cardomain.com/ride/2543199
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by Pete68 View Post
      tough on a 17x9. 9" is minimum on a 275/40. 285/40 needs 9.5, 315/35 needs 10.5
      Scott from NJ.
      Vent Windows Forever! ...
      Mantorville, MN
      If you plan on driving it hard, I'd go 265/40/17 Dunlop Direzza Sport Z1 Star Spec (world's longest tire name?)
      That is one of the top tires in SCCA ST* classes
      Derek Kiefer,
      Mantorville, MN
      Washington, MO
      Nitto 555
      285/40 rear
      275/40 front
      lower it 2.5" all the way around
