Results 1 to 4 of 4
Thread: rear of 1st gen not centered
06-16-2005 #1
Starting The Transformation
- Join Date
- Mar 2005
- Location
- chester Md
- Posts
- 300
ok. i have a 69 camaro. Still stock hieght. I put my new 17 x 10 and tires on it yesterday, and noticed that the rear is shifted about a 3/4" to the passenger side.
Now, how to fix it?
Can i just take the leaf springs loose at the rear, and try to slide it over? I'm looking at the welded brackets and thinking this is not going to work.
any suggestions are greatly appreciated..
Mike
06-16-2005 #2
- Join Date
- Jun 2005
- Posts
- 107
are you sure its the rearend? i know on A-body's the wheelwells vary side to side from 1/8 to 3/8" on never wrecked cars.
on a plus note.... if it is the rearend not being centered, if your gonna be cutting the perches loose..... its a great time to fine tune the pinion angle
06-16-2005 #3
06-16-2005 #4
Banned
- Join Date
- Nov 2003
- Location
- Maine
- Posts
- 1,076
also`
you canmess with offsetting the front spring bushing in the direction you want to gain some also, dse reccomends this when using there offset shackles
jake
