View Full Version : Home made splitter project begins!
nicks67camaro
04-23-2011, 10:06 AM
So this is my attempt at a home made splitter / spoiler. I purchased a plastic lower air dam from a late 90's GM application. I then won on Ebay a front splitter used from a NASCAR application.
The Splitter
https://static1.pt-content.com/images/pt/2011/04/fu9tvb-1.jpg
The air dam was close the the 1967 Camaro factory contour. The entire middle section was close. From the center line of the factory spoiler moving left and right the two migrated from each other about 1/4 away on each side so. I'll need to change the bend but that will be later on.
Here they are over one an other
https://static1.pt-content.com/images/pt/2011/04/x3im3m-1.jpg
The over width of the spoiler needs to be trimmed by 16" so I took 8" off the straight sections where they are not lining up.
The result a new splitter that is as wide as the left and right measurements of the lower front fender extensions where the factory support bars go.
https://static1.pt-content.com/images/pt/2011/04/27yvnec-1.jpg
I need to get my buddy's plastic welder next.......
nicks67camaro
04-23-2011, 10:13 AM
The splitter is 72" wide so i need to trim that by 13" this will give a splitter that is 59" and ends roughly on the middle point of the front tire.
https://static1.pt-content.com/images/pt/2011/04/mujwjt-1.jpg
I need some help on this one. The material looks to be carbon fiber. I was thinking i can cut the middle section out and then rivet them back together using a steel plate backer. Is this the right approach? Of does anyone have a better ideal?
The other question is how to finish it. I was going to paint this as well but can I can DA sand the old paint off and reshoot it. Is there way I can get the paint and slight scuffs off and having the carbon fiber look good? Or is the carbon fiber just not able to get brought back to looking good?
nicks67camaro
04-23-2011, 10:16 AM
this is what it looked like just quickly mocking them up together. The alignment is WAY off but you get the picture...I can't mock up the shorten piece since my brother has all my buttwelding clamps.
https://static1.pt-content.com/images/pt/2011/04/eposd5-1.jpg
gotta squint your eyes a little to imagine it.
nicks67camaro
04-23-2011, 02:21 PM
I was able to mock it up quickly. I think i like this side up. Its slightly off center but looks good i think. I still need to weld it up and tweek it a little but its getting there.
https://static1.pt-content.com/images/pt/2011/04/8x8wef-1.jpg
crazycarguy22
04-23-2011, 06:00 PM
Can you post a pick of it the other way for us to see? A profile pic would be sweet too. But overall it looks good, great idea.
nicks67camaro
04-23-2011, 06:28 PM
sure here is the other way. I didn't have the best angle. I'll try to get a side shot tomorrow.
https://static1.pt-content.com/images/pt/2011/04/2e52xiq-1.jpg
Flash68
04-23-2011, 07:06 PM
Looks pretty good man! Got a side view?
nicks67camaro
04-23-2011, 07:12 PM
Thanks its coming out better than I thought it would. I'll work on the side view tomorrow after the family festivities.
Gitter Dun
04-23-2011, 07:36 PM
Looking good. I've been trying to set aside time to build one myself. Thanks for the ideas.
crazycarguy22
04-23-2011, 08:43 PM
In my opinion, I like it the second way best. Truthfully though, it looks great either way.
nicks67camaro
04-25-2011, 04:22 PM
So the plastic welder took some getting used to but i think it worked well. I did a test piece last night and tried to rip it apart today and it was real strong. The spoiler needs to go back more but its getting there.
Here are some extra shots. I think I'm back to this orientation. The bottom is 6 1/2" from the ground.
https://static1.pt-content.com/images/pt/2011/04/2d9aat0-1.jpg
side view I still need to move it back about 1" to get the contour to line up.
https://static1.pt-content.com/images/pt/2011/04/207n96x-1.jpg
3/4 front shot
https://static1.pt-content.com/images/pt/2011/04/rko9b7-1.jpg
and in front of the tire
https://static1.pt-content.com/images/pt/2011/04/t7laf4-1.jpg
Flash68
04-25-2011, 09:27 PM
Nick, that looks really good man. Nice work.
Nessumsar
04-26-2011, 08:33 AM
What GM car is that spoiler off of??? It looks like it would follow the contours of my Nova bumper really nice!
It should look really sweet when you get that splitter mounted to it! Good work.
nicks67camaro
04-26-2011, 08:49 AM
the application is 1997 Tahoe, I think it covers the 1500 trucks as well. They are all over ebay. They are available with and with out tow hook openings which i think can be used for air duct hook up for brake cooling.
this is with the tow hooks
http://cgi.ebay.com/ebaymotors/GMC-CHEVY-1500-2500-TAHOE-FRONT-AIR-DEFLECTOR-W-TOW-NEW-_W0QQcmdZViewItemQQ_trkparmsZalgoQ3dSIQ26ituQ3dUCI Q252BUAQ252BFICSQ26otnQ3d10Q26pmodQ3d360356902098Q 252B360357224866Q252B310309834420Q26poQ3dLVIQ26psQ 3d63Q26clkidQ3d8731187922125098101QQ_trksidZp5197Q 2em263QQitemZ190522767102#ht_4244wt_1104
Nessumsar
04-26-2011, 08:59 AM
Thanks for the info Nick!
nicks67camaro
05-14-2011, 02:53 PM
Not may updates since i've been crazy busy at work I also decided to drill a small hole in my finger ouch...slowed me down some but all in all its
getting there. Need to install the spoiler support bars, sand off the white, and wet sand out the carbon fiber from under the paint. some pics......
https://static1.pt-content.com/images/pt/2011/05/518xuw-1.jpg
https://static1.pt-content.com/images/pt/2011/05/15n28f8-1.jpg
smhigh
05-14-2011, 07:15 PM
Nice work!
Mr.VENGEANCE
05-14-2011, 07:22 PM
very good!
nicks67camaro
05-21-2011, 12:18 PM
This is as far as it goes for now. I have lots of projects around the house that need to be done so I'll live with this. I still need to use some plastic filler and smooth out the spoiler more. An i still have a bunch of work with DA sander to get the carbon fiber to be smoother.
In front of the tire
https://static1.pt-content.com/images/pt/2011/05/69jfjk-1.jpg
down the front
https://static1.pt-content.com/images/pt/2011/05/209iqom-1.jpg
3/4 view
https://static1.pt-content.com/images/pt/2011/05/xd5aw0-1.jpg
front on
https://static1.pt-content.com/images/pt/2011/05/6sqpmw-1.jpg
zuess4u
10-28-2011, 10:11 AM
Nick,
great work, I think it looks great, Ive been looking for an alternative as well....that didnt cost over 500.00$,,,this may be an option.
newmexicosaint
10-28-2011, 11:03 AM
Man, that looks good!! I have to admit that I was scratiching my head at first (obviously because I don't have the vision you did Nick) but now man I seriously like it.
nicks67camaro
10-28-2011, 02:20 PM
thanks guys, it came out better than I expected. Here is a head on shot.
https://static1.pt-content.com/images/pt/2011/10/15714r6-1.jpg
T_Raven
10-28-2011, 04:08 PM
Turned out pretty good, I like it.
ROBS6T8
10-31-2011, 06:14 AM
Very nice Nick. Great work!
Tom Welch
11-01-2011, 08:04 AM
VERY NICE! I have been studying something like this for my firebird.
firebirddady69
11-05-2011, 12:14 AM
great work!
