Results 1 to 17 of 17
04-22-2011 #1
Rate my budget suspension overhaul, 68 Camaro
Ok, I'm definitely unfamiliar with numbers and how suspension really works (like sway bar thickness, etc).
SpeedTech Tubular UCA (with redrill mod)
Stock Lowers
Hotchkis 2" (possibly 3) Drop Springs
Hotchkis Tuned Bilistein Shocks
Hotchkis Steering Rebuild Kit and Heavy Duty Tie Rod Sleeves
Hotchkis Sway Bar Hollow 1 1/8"
Hotchkis Subframe Connectors
Some form of drop leafs, undecided.
Without drop leafs, it comes out to be just over $1400, from Jegs. Would this be a significant upgrade over a pretty much stock setup? I'm mainly concerned if the SpeedTech and Hotchkis parts will work together? And should I hold off a little longer and get the SpeedTech LCA's? I'm completely open to suggestions.
I haven't ordered anything yet, but if all goes well, I plan to get everything some time this summer.Dan
