View Full Version : Backfiring popping on deceleration
lutzy
04-21-2011, 12:51 PM
Just got my car back after having a cooling system installed and after taking it for a ride it seems to be backfiring and popping out of the exhaust when letting off the gas. It is a 598 BB with a holley 1000 carb. Any ideas? Plugs and wires are good.
nicks67camaro
04-21-2011, 02:04 PM
Was there any exhaust work done recently? I have had a backfire / popping when i fixed my x pipe and missed a section welding it up. I know hearing a slight exhaust leak over a 598 BB may be hard. How are the collector gaskets?
lutzy
04-21-2011, 05:04 PM
No exhaust work done recentley.. Everything is tight. The engine was running on for a few sec's after shutting off but after I turned the idle down it seems ok now.
Henesian
04-21-2011, 05:19 PM
Too much timing? Too rich?
lutzy
04-21-2011, 05:57 PM
Timing is set right, plugs Have a tan color so it's not running rich..
Ron.in.SoCal
Jetting...
sam 74
04-22-2011, 01:44 PM
have you checked for vacuum leaks?
lutzy
05-02-2011, 05:14 PM
was a leaking exhaust manifold gasket..problem solved :)
