    Results 1 to 5 of 5
      Feb 2008
      Melbourne, Fl
      1968 camaro 18x10 backspacing
      Will have it mini tubed but got a good deal on a 18x10 rear wheels. Have air ride and need them to tuck. What backspacing should I have?
      Oct 2006
      Corona, CA
      Stock length rear end? And what tire do you plan on running? It will make a difference....
      Feb 2008
      Melbourne, Fl
      Quote Originally Posted by DriverzInc View Post
      Yes Stock rear end. Tire size I'm open. The reason I'm asking is a got a great deal on some bonspeeds. 18x10 rears with 6.5 backspacing. I know that's a lot. I don't mind adding a 1/4 inch spacer but I don't want to run any more. Do you think that will work? By the way the front are 18x8 with 5 inch backspacing.
      Caledonia, MI
      I have 5.5" of back spacing on the back of my 1968. At 5.5" I have less than .5" of clearance at the closest point of my 275/40/18 Kumho to my stock inner wheel tub. Since you are minitubbed you shouldn't have a problem fitting them under the car. I would just worry that they will be tucked to far under the car and look funny. If I were to reorder my rims today I would get them with 5.375-5.25 just so they would look so tucked.
      Jason Mitchell
      1969 Camaro @ Dutchboys
      Nothern California
      I have a 68 and was going to use the stock width rear (60 1/2" rotor hat to rotor hat) with forgeline 18x11 with 7" Backspacing which left 5" Frontspacing. It would not fit, it was to wide. If you drop a plumb bob from inside of each 1/4 lip and measure mine was 69 1/2". With the stock width rear and 7" BS the OD of the entire rear with rims and tires was 71 3/8". I sent the rims back and had the BS changed to 5.5" and I will be narrowing the rear. With that said I have factory 1/4s on my car and the driver quarter is approx 1/2" tighter to the center of the car than the pass side. That is the same issue on my brother in laws 69 1/4s also. With your car on a stock rear 60 1/2" with 6.5" BS and 4.5" FS it should be 69 1/2" plus the extra section width from the tires add approx 3/4" so that puts you at 70 1/4" OD. Drop string lines down from the inside of you 1/4s and see what that dimension is so you will know. You will have to cut the lips and roll them. Hope this helps. Let us know.
      Guy S.
      68 Camaro LS1, T56, Forgeline WC3
      69 El Camino BBC 4spd A/C Cruise SOLD
      2012 Dodge Crewcab Diesel 4x4
